Jaguar xjs 1982 windows not working
Hi all,
Need your help on this one,
I cannot figure out why my windows stopped working.
tot start, The windows didn't work when I got the car, and thanks to this wonderful forum I cleaned the switches and both windows worked again.
And now since i have been doing some other stuff like replacing all the fuses, main load relay, water pump and cooling hoses, I did not pay attention to the windows any more and suddenly they died on me.
I checked the circuit breaker on the left side fuse panel (brown/blue and brown wire) and it has 12 volts continue (coming from the brown wire trough the circuit breaker to the brown/blue wire) but I do not have any power on the switsches (also brown/blue wire).
Since both windows died I assume it is unlikely that both window motors have died at the same time, searching the forum and internet, it looks like there has to be a window lift relay, but I cannot find it.
Cigar lighter is working
Any thoughts on this one?
The car is a 1982 HE V12 XJS
Have found the relay, for now I just connected the 2 brown/blue wire together using a 35A fuse (maybe a bit to much because there is also the circuit breaker)
But it works, even though the ignition switch is not on.
Do you guys have any ideas for a replacement relay? I found it hard to find one here in the Netherlands.
Hella part numbers or other marks that suits ok as well, Bosch e.g.?
Any input is much appreciated.
orangeblossom (12-28-2017)
Stein Erik Hanssen
08-03-2014 06:33 AM
