Jaguar Xjs 1990 3.6
Jaguar Xjs 1990 3.6
Hi Guys
Hope someone maybe be able to help me here, I have a Jag Xjs 3.6 1990.
The problem is that the idle is very slightly lumpy and at around 3500RPM its starts fart around and pop etc. When driving it holds back.
So far I have tested
Fuel presure Ok
Plugs changed
HT leads changed
Cap and rotor arm changed
Yet the problem is still here,,,,, However I have also noted that the seems to be running lean looking at the analsyer results from the last MOT 2 weeks ago.
CP @ 0.88 and HC @ 98ppm
I think this would explain my high engine temp!
Any help would be appreciated
Fuel presure Ok
Plugs changed
HT leads changed
Welcome to the forum brettb,
I've deleted your duplicate post from General Tech Help. This is the right place for the question and members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Tony K
03-26-2024 01:53 PM
FS[NorthEast]: 1991 xjs v12
DrScientist
12-09-2015 07:36 PM
