jaguar XJS AC Blower Problem
For almost 20 years I subscribed to various Jag-Lovers lists::XK, saloonx and E-type. Those lists helped me through frame-off restorations of six Jaguars (1951-1964) three of which were pictured in a magazine-"Jaguar Enthusiast." Those lists provided assistance online and offlive which helped me tremendously! Now I have used the Forum for the first time and was greatly disappointed.
I did learn what my problem was, but when I asked for someone's email and provided mine,, Graham told me that was not allowed and ended my thread. Now that I know the ruies, I'll try to continue. My apologies to Graham for not knowing the rules.
The problem is my RH blowers runs constantly. I think the access panels should be easy to remove to gain access to the blower. But how do I determine which component is causing the problem and what the part numbers are. Also , where can I get the parts?
Thank you guys for your help.
Frank Morse
1991 V12 XJS conv wirh a Mark III a/c.
so
Frank Morse
so
Received 6,340 Likes
Frank,
I've moved your thread from the new members section to the XJS tech section where I'm sure will get the help you need.
I believe the main reason the other thread was closed was because it was in the "New members section" which is solely for the introductions of new members and not for technical discussions, in addition you did not provide details of your vehicle.
I see you have provided the necessary details now, I'll add those to your signature so they show up in every post. (starting with your next one)
Fmorse,
I was also on jag-lovers for a long time (even back when it was an email list system), and you won't be disappointed here. Best XJS forum with the most helpful and insightful members.
As to your problem, this is a quite common. For some reason the fans are wired in such a way that are always wired 'on' and the circuit turns them 'off'. When there is a component failure the fan is always 'on' rather than not working at all. In the short run you can pull the fuse to that fan so it doesn't run your battery down. In order to fix it, the entire blower unit needs to be pulled and you'll have to solder in a replacement of the failed part. I can't remember the exact one that fails, but if you search the archives you'll easily find posts regarding this and the circuit drawn up (archive search is much better than at jag-lovers too).
EDIT: You might find this helpful on how to remove the blower: http://www.bernardembden.com/xjs/hvacmodule/index.htm
And this on the circuit with the transistor that fails: http://www.jag-lovers.org/xj-s/book/acblower.htm
Fmorse (08-16-2020)
Greg in France (08-16-2020)
The way the circuit works is the circuit is powered all the time and the transistor makes ground when needed. When the transistor fails, it always provides a ground path and loses it's switching function.
Here is a suitable transistor: https://www.digikey.ca/en/products/d...J11016G/919445
Yes, there is a small circuit board inside the blower housing, You'll have to unsolder the old transistor and solder in a new one. Be careful to protect the new transistor from soldering heat, electronics don't like being too hot.
Much of the process is described here: http://www.jag-lovers.org/xj-s/book/acblower.htm
Fmorse (08-17-2020)
OK. I am making progress, but I have hit a snag. I unbolted the blower motor mounts, but the blower will not come out. It appears to be stuck at the top. I opened the recirculation flap at the bottom (it will only open about 1 1/2 inches). I tugged on the blower motor, but am afraid I will break something. Am I missing something?
No, but the bottom flap MUST be open to remove the unit. It is a good idea to use a block of wood to hold it as open as possible. It will be stuck because the rubber gasket adheres very firmly to the body! You just have to use brute force to rock it about to break the seal. If the bottom flap is not wide open the top flap overlaps the body like a lid and prevents the blower moving.
OK. Some progress. I finally got the blower out I think I was not holding the lower flap open enough.. Success!!! I found the panel with the components. It was riveted on. Now I just have to wait for the transistor I ordered. Do I need to replace the other parts? Thanks for all the help so far
Hi guys,
I have removed the blower and replaced the transistor. I hooked up the wiring and the problem (blower running constantly-RH) is resolved.
Now I have a problem reinstalling the blower. I have wedged the bottom flap open but cannot lift the motor high enough to engage the attaching bolts.I think if I can align the top flap with the hole in the cowel it will go higher, but cannot lift it high enough. No wires or anything else is in the way.
Suggestions?
Frank Morse
Suggestions?
Frank Morse
The following 3 users liked this post by Fmorse:
04vdp
12-08-2009 12:40 PM
