Jaguar XJS HE Coil
Received 10,920 Likes
Order DAC6093 or equivalent. The usual Jag vendors will have it or just Google the part number. Use this to replace the existing primary coil. It will mount easily; no changes to brackets are needed.
The wiring to the secondary coil is simply disconnected; remove it entirely if you wish...and the coil as well
The following 2 users liked this post by Doug:
Grant Francis (11-13-2019),
ronbros (11-13-2019)
