just asking
knares (08-12-2018)
The Jag V12 fires alternate sides of the engine , so it fires Right Front, Left Rear, Right Rear Left Front.
Cross plane crank V8's (this is most V8's) fire 2 cylinders on the same side consecutively, this is what gives the V8 its traditional burble.
No engine I know of fires 2 cylinders at the same time.
knares (08-12-2018)
Received 10,871 Likes
From the ROM:
"The injectors are operated by the ECU in two groups of six. Each if further broken down into two sub-groups of three, although each pair or subgroup is operated simultaneously to make up the two groups of six twice per engine cycle."
The following 2 users liked this post by Doug:
Grant Francis (08-13-2018),
knares (08-14-2018)
Well that is correct for most engines. But I had a Hyundai Sonata, with the 4 cylinder engine. It had 2 coils for four cylinders. It fired one cylinder on the compression stroke, and the other one on the exhaust stroke. Motorcycles have used this setup for years, a four cylinder with 2 coils, and four leads, 2 from each coil. So they technically fire 2 cylinders at the same time, only one makes any power. There was a claim, it also helped on emission reduction. I don't know that I believe that.
The injectors are "batch fired" all at once
From the ROM:
From the ROM:
From the ROM:
From the ROM:
And as the Digital P is very well/closely related to some Bosch management systems, you could probably get away using a Bosch 4 cylinder ECU if you somehow found a way to adapt the pressure/vacume sensor to it...
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
knares (08-14-2018)
buddy
08-20-2010 07:45 PM
2002XJ8
09-27-2008 11:01 PM
