Just Bought an XJS!!!
#61
It is hard for me to tell you just how much play it should have and frankly I am not sure anyone can but perhaps so. My suggestion is close inspection of the mount and if any cracks are visible then you may want to replace it. I can tell you that unlike the engine mounts when worn cause the fan to hit the fan shroud when revving the engine, the transmission mount does not cause any immediate damage to anything. The car looks fantastic from the photos.
#62
Thanks daverb! I just got a call today that the paint touch-up/buffing is done and the car is ready.
While at their shop I had them do an oil change. When the owner called me he said you may need to have the transmission mount looked into. He said when it was being lifted they noticed play in the transmission mount. I know the trans is supported by a spring and some play is expected. My question is how much should it move?? Anyone know?
#64
If the mount is worn what wears out? The spring or some other component? It is a really unnecessarily complex unit.
I will add that the car runs and drives very smoothly.
#65
#66
There is a rubber cup and cotton reel when these wear you get noises. You can buy the kit that includes the spring, cotton reel and cup.
Replacing it is not difficult just time consuming as the bolts are above the exhaust which are accessible unless the exhaust has been modified.
#68
#69
A single 3ton floor jack ( low profile ) under the front crossmember ( shim with wood to avoid bending ) will raise it enough. Use stands. A second floor jack for the tranny support / lowering will get it done.
One spring seat, one trans bushing is enough. New spring if you want or need it. One hour job. Two if you haven't had the exhaust apart yet. Looks daunting and reads worse on the internet but it's not bad.
#70
#72
I picked my car up today and it looks great! Night and day improvement in the paint. Well worth the $$$
While there we put it on the hoist so I could check the transmission mount. You can move it up and down an inch or so. Please take a look at the video and tell me if you think this is normal or excessive.
#73
Greg in France (03-11-2017)
#74
#75
Preventative maintenance, you are stopping it clunking/failing soon. Also the diff and UJs and gearbox tailshaft get more stressed than they should with that degree of play. In my view, anyway!
#76
Ha! Interesting way to look at things, I like it
The 'problem' is knowing that it needs to be replaced....but not doing so. This will become a nagging, dogged itch that much be scratched.....the kind that itches so badly that you claw away at your skin until it bleeds.
Well, that's how it always turns out for me, at least!
Worse, if you neglect this repair then....what repair will you neglect next? It all starts going downhill. Soon enough you (or the next owner) will be faced will a long list of 'needs to be done' items...eventually making XJS ownership seem like a very unhappy proposition. This brings about about sadness, depression, lack of enthusiasm and productivity, and withdrawal from the community. The long term eventual result of this is nothing less than a slow, insidious tugging and tearing at the very fabric of society. All because you didn't replace the transmission mount.
How's that ?
The following 2 users liked this post by Doug:
Pawsnclaws (05-12-2017),
paydase (03-11-2017)
#77
Whew, ???? I've tons of deferred maintenance every where ? Your symptoms are tantamount to a Van Gough type madness.
Is that my fate??
No sir. Warts and all, my Jaguar is a source of enjoyment !!! I was at the local Rite Aid Pharmacy yesterday. It is near the retirement community of Rossmoor. An older fellow came up to chat. He admired my car's lines and exhibited a limited knowledge of them. He told me that as a retired carpenter, he did no want driving pickup trucks
any more. He invested in a circa 65 red Mustang convertible. Yes, sir, I've seen you drive that car, a real beauty...
Car guys admire whatever critters....
Well, not mere appliance cookie cutters....
Carl
Is that my fate??
Carl
#79
My book on how to buy an XJS will be up for sale later today, and although I do not address this issue, I do address so many other issues that can cost thousands after the fact. Most items that people think will cost just a couple of hundred but every couple of hundred becomes thousands very fast. I point out in the book the cost of many parts and repairs so the buyer knows what to expect prior to purchase.
There is no way around repairs when the car is yours. The XJS is not a cheap car, so when things are worn, you just have to fix it. You can pay now or you will pay so much more later.
#80
How's that ?
How's that ?
Great post!!!
