Knocking/pinging/tapping sound when engine is running
Old 01-16-2017, 06:35 PM
baxtor's Avatar
Received 1,165 Likes on 754 Posts
Sometimes the journey is just as important as the destination.
The following 3 users liked this post by baxtor:
Grant Francis (01-16-2017), orangeblossom (01-16-2017), ronbros (01-17-2017)
  #62
Old 02-25-2017, 12:48 PM
Normstoy's Avatar
If you have a dropped valve seat is there a loss of power or rough running?
  #63
Old 02-25-2017, 06:35 PM
v1rok's Avatar
In my case (with apparently two dropped valves) the car surprisingly was quite springy, though obviously wounded. The most noticeable sign was fairly strong cluttering sound. I like the description somebody provided earlier: a noise similar to a large sewing machine might produce
  #64
Old 03-07-2017, 05:28 AM
davidedney123's Avatar
My 1992 XJR-S has developed a tapping noise from 6B, and I fear the worst. It was intermittent and has become more persistent. Initially it did it only under acceleration and not at idle or steady speeds but it seems to be getting a bit worse. Odd thing is that if I pull the plug lead on 6B the noise stops.
I'm hoping it's an exhaust leak around the plug or something like that, and have bought replacement plugs. THe noise very much seems to be coming from inside the V rather than the exhaust manifold...
Video:
https://www.youtube.com/watch?v=kWIz...ature=youtu.be
It really does sound more exhaust-y to me.
  #65
Old 03-07-2017, 11:36 AM
JigJag's Avatar
If you pull the plug and the knocking stops it's usually a rod bearing.
Video does not sound like a rod to me.
  #66
Old 03-07-2017, 12:00 PM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Sounds like a leaky gasket... So not a really fun job to replace (not much space at all).
  #67
Old 03-07-2017, 12:03 PM
It really does sound like that doesn't it
Jonathan-W (03-08-2017)
  #68
Old 03-07-2017, 02:46 PM
JigJag's Avatar
What gasket?
I don't see how any exhaust leak jibes with pulling the 6B lead silencing the noise. Unless the exhaust manifold gasket has blown out on one cylinder.
  #69
Old 03-08-2017, 03:42 AM
Daim's Avatar
Originally Posted by JigJag
What gasket?
Exhaust manifold gasket (between head and manifold)...
  #70
Old 03-08-2017, 12:57 PM
Jonathan-W's Avatar
gasket, thanks I will file this video for sound of exhaust gasket blown at head to manifold...
