Lambda O2 Sensors
Hello all.
The post on O2 sensors has got me thinking. Mine are probably the original from when the car was made so my question is would it be wise to change them. I’m not sure what sort of signs a failing sensor would produce. You thoughts as always much appreciated.
Rob.
Rob.
Failing oxygen sensors will usually show up in higher emissions and lower fuel economy.
If they are original, I would make plans on changing them. They aren't made to last forever. Without knowing the miles on your car, I can't tell if you're due, but I would at the very least acquire a set and have them ready.
JJS- Florida (06-26-2023)
