Last time I ask for help on this issue... trans shifts?
Old 01-04-2020 | 08:09 PM
944xjs's Avatar
Originally Posted by Doug
Are you still running two fuel regulators?
I know you just replaced the B-bank unit (I think) but do you still have the inlet (A-bank) regulator in place?
If so, bypass it and see if anything changes
Long story short I had a terrible bucking/cutting out problem with my '88 XJS and it was the inlet regulator that had failed
yep still have the 2... I am planning on getting rid of the inlet regulator. I actually wanted to do it today but wasn’t sure the best route to go. Just bypass the regulator and connect the 2 hoses with a joiner or use one piece of hose? But the connections are actual screw connections not clamps. I’m starting to think it is a fueling issue not spark.
Old 01-04-2020 | 08:19 PM
Doug's Avatar
Bypassing the inlet regulator.....
Note item #10 and #1 in this illustration:
https://parts.jaguarlandroverclassic.../brand/jaguar/
Eliminate item #1 by simply disconnecting it from the fuel inlet pipe and the inlet regulator
Run a new hose from the inlet pipe directly to item #10. The #10 pipe has a knob at the end that you can slip your new over and secure with a clamp
3/8" ID hose as I recall
Old 01-04-2020 | 08:57 PM
944xjs's Avatar
oh ok I think I get ya.. basically on #10 just pull back the nut and put the tubing over the pipe?
Old 01-05-2020 | 09:49 AM
Doug's Avatar
right
944xjs (01-05-2020)
Old 01-06-2020 | 05:02 PM
944xjs's Avatar
right
one last question... what should be done with the vacuum hose off the fpr?
Old 01-06-2020 | 06:17 PM
Doug's Avatar
Just take it off and cap the nipple
944xjs (01-06-2020)
Old 01-06-2020 | 07:18 PM
944xjs's Avatar
cool thanks. It’s what I figured just making sure
  #28
Old 01-06-2020 | 07:39 PM
Bez74's Avatar
Looks like you have been chasing this for a little while - was going back through the forums chasing other stuff and found some of your previous posts
July 2017 looks like you had water in your fuel system - left overs from when you did your fuel tank?
August 2017 very dirty fuel from your sump tank.
January 2018 - having similar issues to what you are having now - so the title of this thread makes more sense to me now, also when you changed from 2 coils to 1
Interesting to read the XJS rev limiter thread #33 https://www.jaguarforums.com/forum/x...-153911/page2/ saying he found and fixed his issue
I am understanding your frustration just that little bit more
Steve
Old 01-06-2020 | 10:12 PM
944xjs's Avatar
Steve
yeah I saw that thread... he went back to 2 coils. I had the same problem with 2 and 1 coil. I even changed the coils when I had 2. I changed to 1 coil last year. I was wondering if the advance was bad cause it wasn’t snapping back. I pulled a distributor out of a junkyard xjs with good advance and vacuum... tossed it in and still the same. So tomorrow I’m bypassing the fpr/pulse regulator whatever and if that doesn’t help... I’m going to test fuel pressure. My only thought now is fuel or timing? I know when I checked timing if I recall it seemed a bit advanced at idle. I think I made a thread about that too. Almost like I couldn’t get the timing to 0..
  #30
Old 01-07-2020 | 03:20 PM
944xjs's Avatar
Alright I’m in a positive place now. I did remove the inlet fpr that didn’t do anything... then I was sitting with it running and just looking around. I started revving it with the cap stand and opened it wide and it started idling funny, up and down. that was new... so I for whatever reason pushed the fuel enrichment switch and the car almost quit. Then it went back to idling weird. So I clicked it again and held it. It revved up and down faster. So I got in the car and revved it trying not to hit the enrichment switch and seemed like it slowly revved past 5k... then I mashed the throttle and instantly cut to the rev limiter feeling back at 5k. I’m thinking the fuel enrichment switch is junk!
  #31
Old 01-07-2020 | 11:07 PM
944xjs's Avatar
I found an old thread on enrichment and it made me less positive. Was saying to test the throttle enrichment switch... at idle if you push the switch and it changes idle significantly that the switch is good. I guess it’s back to fuel pressure testing next
  #32
Old 01-10-2020 | 03:54 PM
944xjs's Avatar
Son of a bitch is gurgling a burgling and burrrring more than ever. Definitely a misfire.
944xjs
11-10-2017 12:15 PM
emilio
08-17-2017 02:42 PM
brgjag
01-06-2015 12:09 PM
ixfn
XJ40 ( XJ81 )
08-21-2011 08:34 PM
Blanco Gato
05-28-2011 10:24 PM
Quick Reply: Last time I ask for help on this issue... trans shifts?
