Leak from 4.0 Autobox dipstick tube
Old 03-10-2024, 04:40 PM
Vee's Avatar
Vee
Vee is offline
Received 1,589 Likes on 1,234 Posts
Its the popular ZF 4HP24 transmission....wouldn't they all have similar dipstick parts?
I also think you would be able to find a used part rather easily?
Don B (03-10-2024)
Old 03-10-2024, 04:41 PM
Vee's Avatar
Vee
Vee is offline
Does it look like this:
​​​​​​https://www.ebay.com/itm/17621136518...Bk9SR8i9-qTFYw
Don B (03-10-2024)
Old 03-10-2024, 04:50 PM
ptjs1's Avatar
Received 3,156 Likes on 2,078 Posts
Hi Vee,
Unfortunately, they all seem to be different. Even the XJ saloons with the same engine and gearbox have a completely different shaped tube.
I can't find the exact one on eBay etc. And with that annoying 90 degree join, where I seem to have the drip leak, I'm not sure I'd trust a used item.
I think I'm going to try and solder mine.
So, a word of warning to everyone when you next change your filter, be careful not to stress that 90-degree join in the dispstick tube!
Paul
The following 2 users liked this post by ptjs1:
Grant Francis (03-10-2024), Greg in France (03-11-2024)
Old 03-11-2024, 05:45 PM
ptjs1's Avatar
Tonight, I decided I really had to get to the bottom of exactly where the leak was coming from.
After cleaning off the join at the bottom of the dipstick tube, I used a wirebrush wheel to remove the paint. I could then see that the 90 degree joint had originally been brazed. But even with a magnifying glass, I couldn't see a split in the brazing.
So I stared through the magnifying glass for 5 minutes and then, Eureka, I worked out where was the problem! There was surface corrosion near to the join and one tiny little pinprick had broken through the surface of the tube from which the tiniest smear of fluid slowly started to escape. I've highlighted it in the second photo.
It's almost unbelievable that a pinprick almost invisible to the naked eye, could cause this leak. It just goes to show how ATF can escape through the tiniest of imperfections.
So, tomorrow, I'll mask off, clean up the whole area more thoroughly, and then quickly smear the whole of that area with some Evostick epoxy metal putty which should seal it nicely, before painting it.
Hopefully that will be the end of a frustrating 2-year quest to stop a persistent drip!
Paul
Mac Allan (03-11-2024)
Old 03-12-2024, 03:56 AM
Greg in France's Avatar
Received 9,413 Likes on 5,516 Posts
Paul
I would use a liquid high temp epoxy glue, like araldite, I am not sure epoxy metal putty will really get into that hole. Good luck and good find, anyway!
ptjs1 (03-12-2024)
RacingGreen87
10-05-2022 03:12 PM
nilanium
01-25-2022 06:28 PM
MK2 1962
16
10-15-2021 03:50 AM
crbass
12-03-2020 08:01 AM
The Coupe
08-04-2020 07:22 AM
Quick Reply: Leak from 4.0 Autobox dipstick tube
