Leaking hydraulic pump / convert. Top
My hydraulic pump that operates my convertible top is leaking fluid. I replaced the u-cup seal and it still leaks. I may have installed it wrong. There is a washer and the seal. I installed the seal first then the washer. It may be in wrong order. Has anyone replaced this seal or have a diagram of the pump?
95 XJS. AJ16
95 XJS. AJ16
I guess I lucked out. I also replaced the snap ring after the washer. But it still leaks. Luckily I bought 2 seals. I guess I’ll re-do the seal.
Are there2 washers, one on each side of the
seal ? I just read and older post mentioning 2 washers. I only saw one and I put that on top of the seal then the snap ring.
