LED dash light conversation mess
Old 05-20-2018, 08:41 PM
Shortcircuit's Avatar
Default LED dash light conversation mess
Hey guys!
Well under the catagory of “can’t leave well enough alone” I decided to replace my rather dim instrument lights with LED. All went well with great improvement to the barrel gauges but the speedo and tach were unimpressive. I pull the cluster unit for further inspection only to find no clues. After reinstalling the unit I have NO gauge lights. Idiot lights work normally. I bypassed the dimmer with no result.
I have confirmed proper ground. Also using an outboard 12 VDC power source found the lights work fine. It appears that there is no power from the gang plug to the unit it’s self. Checked the main fuse. Good. Is there a relay or hidden inline fuse? Any help or idea be great appreciated! Thanks in advance!
Old 05-20-2018, 09:53 PM
baxtor's Avatar
Received 1,165 Likes on 754 Posts
Originally Posted by Shortcircuit
Hey guys!
Please excuse the silly question but, are the led's installed correctly re- polarity.
Old 05-20-2018, 10:34 PM
JigJag's Avatar
I have confirmed proper ground. Also using an outboard 12 VDC power source found the lights work fine. It appears that there is no power from the gang plug to the unit it’s self. Checked the main fuse. Good. Is there a relay or hidden inline fuse? Any help or idea be great appreciated! Thanks in advance![/left]
Have you metered the connector and found power there but it is not being transmitted into the flexible circuit? Or is there no power in the connector?
Old 05-21-2018, 01:48 AM
Greg in France's Avatar
Received 9,330 Likes on 5,475 Posts
Almost certainly one of the copper slightly sprung connectors on the multiplug is not making contact properly. In your case the 12 volt feed to the lights. It is very easy to get these bent out of their proper place when replacing the multiplugs into the back of the unit.
The main gauge lights have small green filters which are best removed completely, but you have to separate the front plastic piece that carries the lenses from the instrument pack itself to get at them. Then your LEDs, or 5 watt push fits in place of the 2 watt originals, will give good illumination.
Old 05-21-2018, 03:45 AM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
Did you remove the green plastic globe covers, these significantly reduce lumin output.
These might help.
Old 05-21-2018, 05:19 AM
Thanks for the reply. I metered the power pin on the connector and there is no power. Fuse is good. There must be additional fuses or a relay that is bad. Dash unit works fine when removed and then powered up. Again it’s only the gauges idiot light work fine.
Old 05-21-2018, 05:46 AM
warrjon's Avatar
There is only 1 fuse main fuse panel no7 for all dash/console/radio lights.
If the centre console and gear selector lights are working then the fuse is good.
There are 3 outputs on the dimmer check you have the wires in the correct position, the Red/White wires are the outputs, Red/Blue is 12v input.
Matts73 (03-30-2024)
Old 05-21-2018, 05:47 AM
Also rhostat has been bypassed by using 3 way jumper
Old 05-21-2018, 06:01 AM
Ok # 7 WAS blown. I was thinking it was 4. I may have had a short on a copper connector when reinstalled. I’ll put it together and check lt out! Thanks again for the help!
Stu 1986
08-03-2017 06:28 AM
Ducmon
11-10-2016 07:17 AM
Razzel
03-03-2016 12:12 PM
MacTzu
10-26-2012 10:27 AM
Quick Reply: LED dash light conversation mess
