LED T10 Dashboard Illumination
Changed my five dash bulb to T5 LED's, but was not satisfied with the illumination of the instruments. Changed the T5's to T10's by slightly expanding the socket hole with a Dermal tool. I still used the OEM sockets and added five T10 W5W 2825 192 194 168 501 Car WHITE SMD LED Side Wedge Light Bulbs 12V purchased from eBay. The single bulb has 20 small individual LED's that provide remarkable BLUE illumination to all instruments.
Greg in France (03-22-2016)
There is a filter on the sockets. Starts out as green but turns black with age which may be the reason for poor illumination. It is better to remove these and use green led instead.
The following 3 users liked this post by baxtor:
The following 3 users liked this post by warrjon:
WARNING LIGHTS
On the 20 warning I used T10's also. These were the flat face type with eight tiny LED's matching the cell color. They were attached to the plastic printed circuit board with super glue and further secured with a gel type adhesive. I would have used two dabs of that new UV setting plastic you see on TV now if it had of been available. I chose not to enlarge the holes because the T10's are large in diameter and I felt that enlargement would possible break down the side walls of each cell. Each T10, wedge type, has two contacts and I straightened out the wires and soldered them to the printed circuit. It is best to solder a short piece of wire on each printed circuit trace (40) before attaching the bulbs. I used a 25 Watt iron and had no problems. I then covered the bulbs soldered side with celluloid material and blue tape. you should insure you have the proper polarity on each bulb before soldering. How do you change the bulbs? I suspect you wont have to since they are supposed to have a 50,000 hour life and they are illuminated for very short periods, if ever. With that UV plastic adhesive you could slip a razor edge under the bulb and pop it off.
Oh yes! They look great day and night.
Sarc (03-22-2016)
1 screw, middle top underside that holds surround trim in place. 1 screw each side holding surround trim. Remove trim. At each end of the upper corners of cluster is a plastic cover that pops off. Under the covers are screws. Remove the deeper of the two screws on each side. Lower steering wheel, or extend fully, depending on model year. Cluster leans out from the top. Remove two electrical connectors from back, and remove the cluster.
macdoesit (03-25-2016)
As Jal says, just the instrument binnacle, but the coloured warning light strip above the main instrument gauges can be removed once the trim surround and the little plastic covers each side of the strip is off (Jal mentioned that these also cover the main binnacle attachment screws). Then you can change or upgrade these little warning light bulbs without needing to remove the binnacle.
Greg
frombenz2jag
41
12-19-2016 04:06 PM
NTL1991
XJ40 ( XJ81 )
03-01-2016 12:31 PM
powerhouse
05-24-2014 07:28 PM
harounq21
03-03-2009 11:42 AM
