Life After the Caliper Rebuild - Need More Brake Pedal!
Ok. Rebuilt the front calipers, replaced pads front and rear, performed ABS bleed procedure and it appears I ran about 4 liters of Castrol LMA through the system. On her first test drive, she stops, but doesn't have a lot of pedal. This is a bit scary for such a heavy monster...
In addition, the "ABS" and brake lights come on for 1/2 second when putting firm pressure on the pedal. They don't come on when easing the pedal slowly. PLEASE HELP!
Thanx in advance!
Thanx in advance!
Thanx, Ken. I'm sure the accumulator will need replacement soon, but the brake pedal was BIG before I performed the work. This car had been sitting for 6 years so I re-did the fronts (slightly leaky left side) and exercised the rears as one piston was a bit sticky. Wondering if there's some sort of technique to engage-in after this type of job to get a bigger pedal on the ABS...
I recall that bleeding the brakes on my old XJS was a bit tricky. You must get the sequence right, far wheels at the rear first, etc. I finally got it sorted out using a positive air presure device at the master resevoir, as I was doing it by myself. I found that the brake system on that car is prone to air pockets and the one way valve technique at the bleed nipple was not cutting it..
Hope this helps as it's been about 15 yrs back that I was doing this job.
Not sure if you got this resolved or not, but if the accumulated crud doesn't get cleaned out of the groove then the seal will retract the caliper piston back too far leading to a mushy feeling piston.
As far as Castrol LMA is concerned, we have been told it's not as readily available at the usual outlets however we have plenty of fluid in stock. If you are in Los Angeles check us out at Steve's Jaguar Service.
Cheers.
Cheers.
wvanepps
10-04-2015 10:01 AM
