Light in Key Dead
My 95 XJS has a light in the key that does not work anymore. I called the dealer and they have no fix for it, not available. So has anyone taken their key apart to see if they could fix it? Maybe replace the battery even though the manual says you can't. I'm hesitant to try to take it apart cause I don't want to destroy it. It's not the most important thing but it would be nice to have it working.
I usually just CAREFULLY cut it open along the seam and replace the battery. It is an odd shaped battery. It is a button style with a raised area. You can get the new batteries at Walmart or a watch sales/repair shop. VARTA V625U.
It will slide back together and if the bulb is good, it will work again.
bob
bob
https://www.jaguarforums.com/forum/x...roject-159355/
I think you were doing the search incorrectly. When I searched my posts for "key", it returned 19 posts.
95 Cat (09-09-2016)
95 Cat (09-09-2016)
thechief1967
03-11-2016 07:46 AM
Tanhands
04-10-2011 12:02 PM
