Lightning bolt warning light -- why is it on?
Received 10,920 Likes
This light will come on when there is a charging problem, so it could be low or high voltage.
I would NOT drive the car until I know what the problem is. If the voltage is high, over 14.8v you run the risk of the battery leaking at best exploding at the worst.
Charging voltage should be between about 13.5 to 14.4 volts. Over 14.4volts or under 13 volts I would suspect a problem with the regulator in the alternator.
Also DO NOT disconnect the battery with the car running, this can cause spikes and kill other electronics in the car especially the ECU.
The following 2 users liked this post by warrjon:
Grant Francis (02-28-2017),
v1rok (02-28-2017)
I'm not so sure! But, I might be getting the warning icons mixed up.
There are two warning lights associated with the charging system.
First is the conventional 'battery' or 'alternator' warning light that operates via the exciter wire....as we see on virtually every car on the road. As I recall the icon is a battery.
Then there's the "over voltage" light ...which is triggered by the "over voltage sending unit". I think this has the lightening bolt icon.
PS- in your opinion how high must voltage be before things start frying? Instruments, blowers, ECU, bulbs, etc?
