Limp Home mode
Limp Home mode
Ok folks replaced the 2 relays for Transmission located over pass.rear wheel arch and still have limp home mode appear............what is further up the food-chain I should check next..............The transmission is in good working order, it I turn the car off then start again the limp home mode goes away and stays off...........the one replay would get hot but a replacement from Welsh Ent. did not fix the issue
Steve Q
1994 XJS 4.0 engine convertible 2+2
Steve Q
4.0 straight six, so drill two small holes on the bottom of your TPS and insert the straw end of an electronic cleaner can, and spray. Crud will come out the other hole. The crud that is tripping your TPS, is what is causing it to go into limp mode. The two drilled holes should allow oil that leaks inside to drip out, instead of pooling. Ive had this happen with every 4.0L that Ive owned. Once drilled it wont happen again.
Doug (06-04-2020)
