Little black hoses?
In the process of replacing some water hoses and fittings (under the driver's side/left air cleaner) I have come across several little thin black hoses attached in various places. What are they and do I need them? (I assume them to be somehow part of the emissions mystery.)
The main reason beyond curiousity is that my wrench slipped and took of two of the little nipples that the hose attach to. I want to know if I should repair the nipple things or if I can forget them.......
So, I went and had a look.... Assuming you were standing on the lefthandside of the engine bay, and that your air cleaner is obviously not on the engine currently, your little thingy looks like this on mine....
![](https://www.jaguarforums.com/forum/members/sarc-4188-albums-posts-1216-picture-imag0389-3210.jpg)
It looks like you have only 2 vacuum lines, however I have 4, but I'm guessing the basic functionality of this part is the same. From the repair manual, this part is a Thermal Vacuum Valve, shown on the centre of this schematic....
![](https://www.jaguarforums.com/forum/members/sarc-4188-albums-posts-1216-picture-image0-3211.jpg)
It's used to purge out the charcoal cannister which in turn is venting from the fuel tank. In other words it's part of your emmissions system. When I first got my car none of this was connected, and the car still ran fine, but I'm guessing it's going to have some impact on your SMOG results, how much I don't know.
Anyway, now that you know whats its called you can get a replacement. I looked around and unfortunately the cheapest I could find was a used one for 100USD
clubairth1
29
05-10-2024 12:57 PM
