A little help please
Received 10,871 Likes
I've always used old fashioned green anti-freeze, Prestone or NAPA house brand, in my Jags. I duuno if that's "best", but nothing bad has ever happened.
What's in the system now? If you have any reason to believe the system has been filled with some other formulation (DexCool, for just one example) then you won't want to mix different types.
ptjs1 (10-23-2022)
As Greg has said, a good time to drain the whole lot and replace. If you're not sure what's in there, it sounds like it hasn't been changed for a few years, so needs replacing.
If it's green / blue, the chances are that it's the older IAT f(Inorganic Acid Technology) fluid which probably has silicates. If it's red, there's a chance that it's OAT (Organic Acid Technology) which is probably silicate free. You don't want to mix those two.
Once drained and flushed through , if you're really not sure what was in there, maybe fill with a HOAT (Hybrid Organic) which should be ok whatever was in there before.
Paul
Paul
Greg in France (10-23-2022)
Paul
Paul
The following 2 users liked this post by jal1234:
Brewtech (10-24-2022),
Timeisrelative (10-23-2022)
The following 2 users liked this post by ptjs1:
Greg in France (10-23-2022),
