It lives but don’t move
Slave cylinder location
where is the slave cylinder located. I think I am ready to bleed the clutch. I found the leak on the master cylinder( the reservoir was had a crack) fixed it and cleaned the cylinder out. It builds up pressure on the my desk. I can not locate the slave cylinder though. As I have said before I work on vintage US cars.
orangeblossom (06-09-2018)
orangeblossom (06-15-2018)
i dont know what a valet switch is. Does it turn off the alarm? I hooked the alarm system up and it chirps every couple of seconds
There were clogs of built up “mud” in all the lines and in the master cylinder. I used a vacuum pump to to pull from both directions and it slowly broke the mud loose. After that I flushed the system by bleeding every connection from the master cylinder to the slave cylinder. I continued to bleed the system until only new clean guild came out.
The leak at the master cylinder was a small crack in the reservoir cases by the rivets being pulled to tight at assembly. I cleaned and epoxied the crack.
It it took a couple hours to bleed the system and two days for the epoxy to fully harden. The jag runs better the more it’s let to run.
orangeblossom (06-17-2018)
Uncle Fishbits
04-02-2017 02:31 PM
84bluexj6
12-25-2012 12:02 PM
