It lives but don’t move
Old 06-07-2018, 11:00 AM
bladerunner919's Avatar
Where on the planet are you?
Old 06-07-2018, 04:39 PM
Andypayne86's Avatar
Missouri, USA. I know I will probably have to ship it. They want $200 for a new clutch master cylinder. I saw a free posts about rebuild kits and thought I’d go that route. The car has 86000 miles on it
Old 06-09-2018, 04:40 PM
Default Slave cylinder location
where is the slave cylinder located. I think I am ready to bleed the clutch. I found the leak on the master cylinder( the reservoir was had a crack) fixed it and cleaned the cylinder out. It builds up pressure on the my desk. I can not locate the slave cylinder though. As I have said before I work on vintage US cars.
orangeblossom (06-09-2018)
Old 06-15-2018, 05:04 PM
I fixed it!!!! Even took the big cat down the road.
orangeblossom (06-15-2018)
Old 06-15-2018, 07:34 PM
Eaa's Avatar
Eaa
Eaa is offline
That switch on your steering column looks a lot like the "valet switch" for the alarm on my car - 91my - cant tell if its in the same place though. I'd guess that's what it is.
Old 06-16-2018, 05:58 AM
i dont know what a valet switch is. Does it turn off the alarm? I hooked the alarm system up and it chirps every couple of seconds
Old 06-16-2018, 09:11 AM
orangeblossom's Avatar
Received 3,812 Likes on 2,639 Posts
Hi Andy
Well done Bro but what was wrong and how did you fix it?
  #28
Old 06-17-2018, 07:49 AM
Originally Posted by orangeblossom
Hi Andy
There were clogs of built up “mud” in all the lines and in the master cylinder. I used a vacuum pump to to pull from both directions and it slowly broke the mud loose. After that I flushed the system by bleeding every connection from the master cylinder to the slave cylinder. I continued to bleed the system until only new clean guild came out.
The leak at the master cylinder was a small crack in the reservoir cases by the rivets being pulled to tight at assembly. I cleaned and epoxied the crack.
It it took a couple hours to bleed the system and two days for the epoxy to fully harden. The jag runs better the more it’s let to run.
orangeblossom (06-17-2018)
Old 06-17-2018, 09:56 AM
Well done Andy!
You got there in the end
84bluexj6
12-25-2012 12:02 PM
jagFan09
10-27-2010 11:32 PM
WhiteXKR
09-13-2010 08:52 PM
Quick Reply: It lives but don’t move
