Loud Humming sound at 600-800Rpm, disappears at 1,000 Rpm and more
My ‘91 XJS LeMansV12 is almost perfect and is in very good condition. She received all major service and replaced all hoses, etc.
I did have to rebuild the GM-400 Automatic and she is now ready for years of spirited driving.
When I received the car back from the tranny shop she warms up gently, all gages are good, and than she starts “Humming” loudly at around 600-800 Rpm somewhere in front of the engine, not “in” the engine? The engine is very smooth and quite.'
It is NOT the idler cam tensioner because that sound is higher pitch and this was checked.
We are now checking the oil line that we suspect has a valve inside that lets oil through and at a certain pressure/Rpm might vibrate enough to cause this humming sound?
The sound is obvious when you open the hood/bonnet and resonates quite loudly when you are behind the wheel in the car.
We are locating an oil line to replace the current line and see if this solves the problem.
My shop is a Jaguar expert and has not ran into this issue before and has trouble locating the sound.
- Does anyone on the forum ever ran into this issue before?
- Is there any reason why taking the gearbox out and reinstalling it have anything to do with causing this sound at lower Rpm?
Received 10,979 Likes
Beautiful Jag.
Any hose or pipe with fluid running through it can create an odd noise under the right circumstances. Moaning, knocking, humming. Vibration/rattling.
I've experienced this sort of thing a few times over the years on various cars and have been lucky enough to solve the problem by simply slightly re-positioning the offending pipe or hose....which has been enough to alter the flow characteristics and eliminate the noise. The same might work for you. In your case the transmission cooler hoses and pipes would be a likely culprit.
That being said I'll mention that a moaning sound on engine start is rather common on V12s and, according to Jaguar TSBs, harmless. It's caused by air being evacuated out of the oiling system. However, this sound typically lasts only a few moments following a cold start so it doesn't really match your situation.
Grant Francis (03-22-2021)
Thanks Doug
I’ll relay this message to the shop.
The initial moan at start up is common, yes.
This pretty loud humming buss starts happening when the engine gets at temperature.
The warmer she gets, at some point at normal running temp, the louder the moan/buss.
Than it goes away at 1,000Rpm
Greg in France (03-22-2021)
Grant Francis (03-23-2021)
When discussing the replies with the shop he said none were the problem.
After spending considerable time locating the sound he zero’d in on the Oil cooler line.
He says there is a valve in this line that is probably sticking or not opening correctly or something and causing a vibration sound?!
We are trying to locate a used line, a new one is very pricy, and before removing it testing other options one last time.
The shop having worked on all older Jaguars for decennia’s says he has never ran into this issue before.
The possible issues mentioned he is familiar with.
The sound was located with this oil cooler line and that is where we are going to try to get rid of the sound problem.
/ The Car is running fantastic otherwise.
Grant Francis (03-25-2021)
Your market would have the Full Flow oil cooler system I reckon.
That valve is inside the oil filter housing, and rarely gives issues.
BUT
Oil filters can. NOT meaning an Elcheapo filter at all, just sometimes the oil filter can cause noises you describe.
Before spending $$ on pipes and hoses, swap the oil filter for another brand.
One model Toyota LandCruiser V8 down here did similar with aftermarket oil filters, and replacing that with a Genuine filter stopped that noise, NO idea why, we just used OE oil filters on any V8 Toyota that darkened our door.
The following 3 users liked this post by Grant Francis:
Don't wanna be picky with your checks, however... Did they changed the alternator's drive belt? Rear/small alternator's bearing gives sucha noise and you won't spot it unitl it gives nice blue flame... Noise will also disappear with higher revs. Use automotive stetoscope on your alternator body to exclude it...
Greg in France (03-26-2021)
Spoiler
The shop believes they found one in France.
When the engine gets warm, the oil pressure gage showed very little pressure.
This is a faulty oil pressure sensor which is fairly common and will be replaced.
We thought the oil pressure may be part of the buzzing/humming issue but wasn’t.
When the parts have actually arrived, and they are good, replacing the thermostat won’t be easy.
Having an almost prefect looking and running LeMansV12 will make me happy.
Knowing all mechanicals are good makes it even better.
I love driving this car?!
Grant Francis (05-22-2021)
REVANTH KUMAR
08-07-2019 06:08 AM
Dell Gailey
08-23-2018 03:07 PM
