Low RPM when cold, when warm RPM OK
My problem:
When is engine cold, I have only 500 RPM.
When warmed, I have stable 800 RPM.
But:
- AAV is working good, Open when cold, closed when warmed.
- supplmental air valve (I have 45 sec timer, US model) is working good, closed after 45 sec.
- temp sensor working good (growing to "N", when engine is warmed).
- TB butterflies are set to 0,05 mm both
I don´t know, where to begin to find why it is so.
Thanks Roman.
But:
Thanks Roman.
roman_mg (08-22-2018)
Thanks ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Crackerbuzz:
I have 1988 XJS, H.E.P-EFI (Lucas). I think, that I have no cold start injectors. And I have CSR ? I think no.
Grant Francis:
AAV is one year old (was new) I will try clean it with WD40 or butterfly cleaner.
Timing (engine advancement ?) is set to 18° BTDC (3000 RPM) and I checked it with stroboscope. I think, that Your second attch was about it.
I am stunned, that I have no "startup reduction of RPM" (from cca 1100 to 800 RPM) when AAV slowly closes. I have 500 RPM after start and after 2-3 km when engine is warmer, 800 RPM. All RPM when "P" is set.
Crackerbuzz:
Grant Francis:
OK.
New can still be out of whack, law of V12.
Ensure the throttle bodies are CLEAN, as they do "goo up" with the standard V12 Goo. This blocks the disc air bleed, and can reek havoc.
Most of mine run at about 20+ deg, no timing plates, so not real sure, but definately more than 18. I never time one the old way, too scary, so "drive timing" is the best way to compensate for fuel, wear, age etc etc.
The following 3 users liked this post by Grant Francis:
Received 10,873 Likes
You don't. Jaguar stopped using them on the V12 around 1983 or so.
The higher idle when cold can be very easily duplicated, if desired, with your right foot pressing the throttle
I drove my previous V12 for years with an inoperative AAV. I removed the AAV entirely on my present V12. I have no issues dealing without high idle speed when cold, Start engine, drop transmission into gear, drive the car. Only when the weather gets near freezing does the engine complain.....but I just nurse the throttle for 30 seconds or so until the engine stabilizes and all's well after that.
The following 2 users liked this post by Doug:
Grant Francis (08-21-2018),
Thanks.
Grant Francis :
I will check my butterflies. I suspect, that fuel portion does not respond air portion. (is higher). And thanks for "goo"
I know new word, my English is from secondary school (40 years ago), But Oxford dictionary helped me ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Vacuum advance is new and working under vakuum good. "Hissy" - next new word![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Doug:
CSR - I thought.
AAV is working good, It is clear, I can replace AAV with foot, but I am "stickler ?" and want to know WHY it is not good![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
I must measure butterflies gap, Something tells me, that I have enough fuel but not air.
Cheers Roman
Grant Francis :
Doug:
CSR - I thought.
Cheers Roman
Roman
Good plan to check everything. Having said that if the tickover is OK when warm, I think that enough air is getting through the butterflies.
I still think, if there is a fault at all, that your AAV is not opening sufficiently when cold. How sure are you that it is absolutely all the way open?
Also, in principle, what is wrong with a steady 500 rpm when cold, if the engine does not stall? Not all AAVs are identical over the years, either, so it is possible you have a perfect AAV that only does give 500 rpm cold.
Good hunting anyway.
Greg
Greg
Roman
Greg
Greg
roman_mg (01-16-2020)
Hi DOUGGY
As has been already said, there was a Service update, that recommended using a Stronger Spring, so it might be worth checking to see if its listed under a different Part Number (ptjs) will know
So fitting one of those Stronger Springs may well solve your problem for just a few $$
l have the same issue, is this the cold start relay?
https://xks.com/i-6919017-jaguar-luc...1-546-100.html
Cheers AOI
Cheers AOI
sheppy
12-22-2014 08:03 PM
svldvc
02-12-2011 01:46 AM
