lt rear brake binding
My 86 xjs was stored in a garage in central california (pretty low humidity) for about 4 years. I got it out of storage, but the left rear brake won't release. Was able to pry the brake pad away from the disc and turn the lt rear wheel freely, but as soon as I applied the brakes again, it locked up. I was able to drive a few miles, but the pad started to overheat and smoke (that's when I realized I had a problem). Tried to bleed some fluid out, but the bleed screw was frozen.
Anyone have luck freeing the bleed screws? Any tricks?
Is there a proportioning valve of some type that might be stuck, keeping to much pressure to lt rear brake caliper? Is there valve between lt and rt rear brakes? Any help appreciated. I'd love to get this car driveable!
Guest
Posts: n/a
One of the problems that brake fluid has is that it attracts water. As you use your brakes that water is pushed towards the slave cylinders. After parking the car for four years you have (likely) rusty cylinders and rusty pistons. These are binding together causing your problems. Rebuild the calipers and while you are in there, check the pads and rotors.
I flushed alot of brake fluid through them, and then pried the brake pads apart enough to get the pads out. Once the pads were out, i was able to force the pistons all the way open. I then put the pads back in and forced them open, the pumped brake pedal to close then, then repeated about a dozen times per side. Seems to work well now.
Sacrider, it looks like we're both still having the same problem with our brakes binding.
To answer your question about proportioning valves, on my 84 at least, they don't exist. I've taken apart the entire brake system on this car. I've replaced the Master Cylinder, Brake Booster, all 4 Calipers and have bled the entire system and am still having problems with my brakes binding. I'm totally at a loss!
90 XJ-S, is there anything else that might be going on?
Anyone else?
Anyone else?
