Lube Marelli Dizzy?
Lube Marelli Dizzy?
I'm currently elbows deep in a distributor cap, rotor button, plug, plug wire replacement. Took the V all apart, I'm getting it nice and clean. Question becomes, should I lubricate the rotor in the distributor? It's a Marelli car, so there's not much literature on what you should or should not do with that distributor. Everything pertaining to lubrication is with the Lucas one. Help!
coventryfan (10-14-2017)
