Lucas distributor rebuild or not?
So I am moving along with my new project and removed the distributor cap and wires which appear to be original form 1985 so they will be replaced.
I checked the centrifugal advance on the CEI distributor and it appears to be working. I rotate the rotor counter clockwise and it snaps back into place.
My question is would it be wise to just go ahead and remove the unit and refresh it like the Kirby says in the book?
While they say it is an easy job in the book it sounds a bit sketchy to me and not very clear. It also seems like you could damage some pieces that I have no idea if you could find.
Is there a source that rebuilds these units?
Received 10,908 Likes
That sounds like good distributor movement to me. If it moves back smartly as you say it is good. Personally I wouldn't mess with it, other than lubricating as DD suggests.
You can test the vacuum advance for movement by sucking on the hose. Once everything is back together, put a "T" in the vacuum line to the advance and check the vacuum with the engine running. If your car has a vacuum regulator (which I thnk
an '85 does?) it will read about 10" at idle. Rev the engine to about 3000 RPM and it should read about 15". If it reads zero at idle and doesn't respond to changes in throttle, you've got something wrong.
Cheers,
- Will
Cheers,
Will
Cheers,
- Will
Cheers,
Will
Cheers,
- Will
Cheers,
Will
Cheers,
- Will
Cheers,
Will
I thought we where dealing with cats not lions LOL
Right it may be in some ways this is an advantage that no one seems to have touched the car. Of coarse it needs some maintenance but its not buggered up as the English would say..
1985, advance, cei, centrifugal, checking, distributor, distributors, good, idea, jaguar, lucas, overhaul, rebuild, rebuilt, xjs
