Lucas ignition no start
Guys
Interesting condition yesterday. My car, having been performing perfectly recently, flatly refuse to start yesterday morning when I tried to take it out of the garage. The car usually starts instantly, therefore tested for the following:
Injectors clicking: yes
Fuel: yes
Power to coil positive: yes
Therefore deduced something to do with coil switching system, ie Lucas ignition amplifier or Lucas dizzy electronics on my car. I had a couple of years ago replaced the HEI module in the amp as a precautionary matter, so I was fairly sure it was not that. I knew that the shielded wire to the ECU was 100% for the same reason.
The WoOZ (aka The Great XJS Prophet Grant Francis) has long held that the condenser inside the Lucas amp goes home and if so, car will not start. I remember this fact and decided to remove it from the amp, which is very easy to do as it just unscrews from the amp chassis and unclips from the HEI module once the amp is opened up. (We will gloss over at this point that I had brainfade and clipped the zener diode wire first by mistake, so that was reconnected ASAP - it has been a hard week of partying...)
The pic below shows the Lucas amp interior, it is part labelled C that is condenser that is removed, A is the zener diode that apparently is an over-voltage protection device for the ignition electronics in the event of a plug or HT lead failing.
Anyway, replaced amp, car started right up. Interesting, huh?
Greg
Fuel: yes
Greg
The following 3 users liked this post by Greg in France:
Guys
Fuel: yes
Greg
Fuel: yes
Greg
This should be of mega interest to all the Lucas 'bods'
Received 1,236 Likes
orangeblossom (04-18-2016)
The Zener Diode is there to suppress the high transients generated (large voltage spikes), the zener acts like a voltage regulator.
The condenser is a capacitor its primary purpose is to prevent arcing as the points open, if this fails (it will usually short out) and prevent the primary of the coil discharging.
The following 2 users liked this post by warrjon:
Junkyardjohn (05-14-2021),
NOPE.
Save the money for spouses 51st.
10 years now, NO condensor, NO noise, NO issues.
I dont even run that silly "Shielded wire" from the amp, until that wire gets inside the cabin (complicated to explain to those that have not delved that deep into the XJ-S, and Greg has I know), and my amp is NOT in the engine bay anyway.
Less weight, so more SPEED, whoopee.
The following 2 users liked this post by Greg in France:
Grant Francis (04-18-2016),
Warrjon
Re: arcing. I knew that is what condensers did on a points ignition, I did not know it was needed for that purpose on the HEI, and presumed it was there for radio interference or some such. Do you recommend replacing the faulty one with a new one then?
Greg
Greg
If you get ignition noise in the stereo put a 1000uf 24v electrolytic with a small 0.1uf in parallel across the radio power lead.
Greg in France (05-17-2016)
Michael Wittmann
03-29-2016 05:16 PM
Michael Wittmann
03-27-2016 07:45 PM
