Lucas ignition years - What type of connectors for the fuel injectors
I have a 90 XJ12 but the ignition system is the same as the pre 89's. Does anyone know what type of injector connectors used? I bought Bosch EV1's but they don't fit and click on.
Only the low profile EV1 type connectors will fit. E.g.
TE PN 825414-5 or
826008-5
AMP
TE Internal #: 826008-5
Timer Connector System, Housing for Female Terminals, Wire-to-
Wire, 2 Position, 5mm [.197in] Centerline, Sealable, Black, Signal
Thanks, that is the challenge. The angle of the injector terminal makes it impossible to latch.
The connectors with the half moon cutouts are required. As in the photo in the second link we were posted by F G, and not as in the photo in his first link.
Greg made a good point about the cut out. Here are snips from the TE PDF as well as drawings for "maybe" a couple of alternate connectors including a knock-off version that looks easier to disconnect (IF it fits)The
The numerical -# variations tend to indicate different plastic colors.
Unknown if the cutout below is big enough:
PN 037 906 240G below for AMP connectors - By KingKong connectors (unknown fit but looks plausible)
Also PN 829441-1 looks the similar.
