MAF reading in grams per second?
Old 10-19-2016, 06:20 PM
Hitch's Avatar
Default MAF reading in grams per second?
Does anyone know or can they check with their advanced level scanner how many grams per second the Mass Airflow Senor should read?
Mine is reading .9 at idle (1100) and only .21 as I blip the throttle to 2000 RPM
That seems low but I'm not sure.
Old 10-20-2016, 09:28 AM
Jonathan-W's Avatar
hmm...
Old 10-20-2016, 06:35 PM
Hitch's Avatar
OK..no love here.. haha
How about volts?
Need some help here people. Trying to get this thing running right.
Jonathan-W (10-21-2016)
Old 10-21-2016, 10:55 AM
Jonathan-W's Avatar
my reply was not help full. I could not delete it, so I replaced it with a Hmm...
it looks like and inverse value that will approach 0
more of a hot wire MAF reading... or a MAP reading of vacuum...
I had no useful value to contribute
Be patient some one will see the post and chime in...
Old 10-21-2016, 02:59 PM
Vee's Avatar
Vee
Vee is offline
Received 1,562 Likes on 1,213 Posts
Pin 1 is at 12v
Pin 3 is at Ground, 0v
Pin 2 operates between 0-5v, depending on what's going through the MAF.
Flow rate should be measured in kg/s between 0.0 and 0.3
Hitch (10-22-2016)
