Magnetic pickup at rear diff, what for?
Old 02-01-2013 | 11:03 AM
Mish_Mish's Avatar
Default Magnetic pickup at rear diff, what for?
I have magnetic pickup where drive shaft bolts onto the diff. My car is '82, with manual speedometer, no ABS and no trip computer (thank god, what an ugly thing it was). So, where does this pickup go and what does it do?
Second question, there is only one electric connector that comes out of TH400 automatic gearbox, it is one wire, where does it go and what does it do?
Thanks!
Old 02-01-2013 | 11:28 AM
howlinowl's Avatar
Just a guess, but maybe it's the cruise control sensor.
howlinowl
Old 02-01-2013 | 11:32 AM
Greg in France's Avatar
Thanks!
Mish, I think it must be the kickdown switch wire that you will find goes to the throttle cable switch.
Greg
Mish_Mish (02-01-2013)
Old 02-01-2013 | 12:47 PM
MustangSix's Avatar
howlinowl
Sort of. It's the Vehicle Speed Sensor (VSS). It provides a speedometer pulse for the ECM, Speedometer, and cruise.
Old 02-01-2013 | 01:25 PM
Doug's Avatar
If an early 80s XJS/XJ6 has the driveshaft sensor for the cruise control then it also has the old fashioned cable driven speedo.
When Jaguar went to the electric speedometers then the cruise control, trip computer (when fitted) and speedo worked off the same signal.
Old 02-01-2013 | 10:33 PM
Mish_Mish's Avatar
Got it, thank you all!
aholbro1
08-05-2021 06:02 AM
FrickenJag
09-25-2016 09:00 PM
afterburner1
12-16-2015 01:12 AM
1100me
09-07-2015 07:26 AM
jfitzoz
09-07-2015 05:28 AM
Quick Reply: Magnetic pickup at rear diff, what for?
