Magnetic plug removal
I guess I'm one of the lucky ones that has a magnetic drain plug in the rear diff. What size is it and what do I use to remove it? I tried one of those Gator Grip universal sockets on the end of a 1/2" breaker bar, but all I got was some small pieces from the corners that fell to the floor. Is all hope lost, or can it still be taken out?
Cheers,
Allan
Received 10,872 Likes
This is probably a good time for a reminder to always make sure you can get the fill plug out of differentials, transfer cases, transmissions etc. BEFORE you remove the drain plug.
I know its not quite the case here, but, it doesn't hurt to keep in mind for other situations. You're kind of up the proverbial creek if you've already drained your fluid and can't get the fill plug out.
rgp (08-13-2013)
aholbro1
08-05-2021 05:02 AM
