Making a new Injector Harness for the H.E
#41
Hi Bro
Welcome home but check this out, now that's what I would call a Wiring Harness!
https://www.jaguarforums.com/forum/x...rl-out-172408/
The following 2 users liked this post by daverb:
orangeblossom (11-27-2016),
paulyling (11-24-2016)
#42
Looks like your getting a handle on it, and you will notice the difference once the new one is on. nails or hooks, it does not matter as long as you have things separated to make the build easier. Just remember, do one wire at a time, and if your using the old plug (I did on mine) leave it connected so you have a reference were to connect each wire.
If that extra plug was like mine, it was not connected to anything, it was bent back and wrapped int the insulation. I will get a picture on how the plug this weekend are labeled for your your reference
thia diagram helped me a lot to match up with the plug
this is the plug from the engine bay harrness
#43
Thanks Dave, I appreciate the help mate and the schematic. I think I will print a copy of yours out as well
I bought brand new Bosch Plugs but I will be splicing into the multipin connectors on the other end after they have had a clean up of course.
#44
Crikey it pays to shop around. I wanted some solder heatshrinking inline crimps for my wires going back to the plug I am re-using. $17 for a pack of 5 Navra ones in Repco. Walked up to Jaycar (Electronics Hobby Place) and they had the same ones for $5 for a packet of 5. They look identical. I hope they are ok but gee it pays to shop around!
I also needed a substitute for these heat shrinkable boots to common up my wires:
Found a pack of 10 in Jaycar for $5 and bought some regular heatshrink too.
I figured with the money I saved I can by myself this sexy overpriced Bosch Air Gun from Bunnings on the way out....I don't like the gas types and uses the plug in type at work with much success:
#45
The following 2 users liked this post by warrjon:
#46
When I worked in an Electronics Workshop I used to use RS all the time and found that their big catalogue they used to send us was easier to find stuff in there than the web page. I don't think they have printed catalogues anymore though.
#47
paulyling (11-25-2016)
#48
Well, kids back to school and it is time to make some progress. Today I focused on running the wires for A bank.
First problem: I nominated the colour Pink for my "KB" wire and after running the wire down today I found out 3 metres isn't going to be enough to do the job (as I use more of this colour ). I also realised I didn't order enough braided sleeving either so I have had to obtain another quote for a bit more ()
Anyway, it didn't stop me making progress. As mentioned above I started with the KB wire (pink in my case) for the first group in A bank (5A,3A,1A). I laid them down and routed them to where they "common" up to the insulated boot.
Next I needed the other wire for the first group so I nominated blue.
I taped the bunch of wires with some masking tape for now to keep them together.
Next I did the other group which is 6A,4A,2A. As mentioned I ran out of pink so just did the other wire which I nominated the colour white. I also cut my braided sleeving to size. Looks a bit of a mess but it is taking form:
Whilst I am waiting for more "KB" I'll continue the process next by doing the B bank in much the same fashion. Then I can move onto making my first Bosch Plug connection.
One strange find from today: I found out what the second plug does....sort of. It only uses two wires coming out of that centre pin. The other two were cut off. The two wires go to each side of the bank where they are dead ended. Weird....only the dead end on A bank has two wires coming out and they connect straight to the earth via a bolt on my intake manifold near the fire wall. So all this plug is for is an earth? Can anybody elaborate what this plug used to be for?
Here is a pic before I ripped it out the other week:
This is all it is. Two wires going to each bank commoned up and connected to earth. (well it was until I cut it out). If I can confirm this to be so I am going to do a away with the plug and just pick up an earth closer to the main plug where the harness plugs in.
Also I sure am glad I decided to do this harness...look how crispy some of these wires are:
orangeblossom (11-28-2016)
#49
orangeblossom (11-28-2016),
paulyling (11-27-2016)
paulyling (11-28-2016)
#51
Progress today:
Still waiting on more "KB" wire but laid out the firing conductors for B bank:
Next it was time to finally do the first Bosch plug. First things first, check which wire goes where. I am not sure that it matters as it is just a coil however I kept it the same. Started with 5A looking down the plug it was KB on the left and the firing conductor on the right. For me Pink on the left Blue on the right:
Firstly it was running the pair of wires through the sleeving and into the boot. I also put some heat shrink over the boot so I can pull it down and shrink the sleeving to the boot after I finished:
Now, the only thing I am not sure is with these little white rubber stoppers. I put them on next:
Strip back the wire and slide the crimp on:
Next do the crimp. My cheap charlie crimper I got from Jaycar done a bit of a hack job but it is ok. I used the jaw that said 14-18AWG so it should have been the right one:
The crimp seemed ok however I put a dab of solder on it to finish it off:
Next I clicked in the connectors noting they go in the way where the little tab has a guide to slide through inside the connector. You will know you get it right when you hear a little "click" and you can't pull the connector back out.
I also slid up the two white little stoppers. Hoping that is what they are meant to be for. (The old harness does not have them).
You can see the connectors have came all the way through:
Next I pulled down that heat shrink and shrunk the boot and sleeving together:
And wella! The first Bosch plug is away!
I can do three more and then I am waiting on wire. 11 more to go...
The following 4 users liked this post by paulyling:
#52
The following 2 users liked this post by Greg in France:
orangeblossom (11-29-2016),
paulyling (11-29-2016)
#55
No more work today as I have to go out. Thursday will do two more Bosch plugs and then I am waiting on more KB wire.....I guess the breaks in between help me to slow it down and think about it more but I surely want to finish this off before I got back to sea as when I come back in January I will be scratching my head wondering where I was up to!
#57
Uncle Lucas sure had some strange ideas about making these harness's though!
Oh and I had to What "Pukka" meant as I had no idea!
In UK slang, it can mean "genuine" or simply "very good"
orangeblossom (11-30-2016)
#58
More progress today:
I had a call from the very knowledgeable 34by151(my good mate James) as his internet connection was too slow to post on the forum (yes...in Australia we still have 3rd world internet at times).
He told me those white plugs are to be stuffed all the way up the plug as far as the tab as they stop vibration, take up the strain and also moisture I think he said.
So...with that in mind I shoved em' on up for the next connection as so:
The narrow most part up as far as the "tab" (was that far enough?)
The little white plugs have 3 fins or "notches". I could get two up there but 3 seemed a bit too much to fit.
Plug went click and I pulled the boot over and heatshrunk the sleeving to the boot. It doesn't look as good but I also cable tied the boot to the sleeve for extra support...I don't want to have to do this again any time soon:
3 plugs made and thats all I can do until more wire arrives (which should be tomorrow or Monday)
Now to start making "T" pieces of the braided sleeving. I firstly cut a hole in the main sleeve:
Slid it all in and made the sleeve flush
Pushed up some heat shrink and had it ready. I am not going to shrink it yet until I get all the wire through:
Starting to look a little bit like a modern harness:
To be continued....
To be continued....
orangeblossom (12-01-2016)
#59
paulyling (12-01-2016)
#60
Well my extra wire came in so it was back to work. A milestone today in that I have finished fitting off all the plugs and I am getting close to the installation
Today I started by "commoning" up the KB wires and each of the firing conductors for bank A. I found it easy to strip back and twist two together first:
Then do the same with the other two wires (3 per bank and one wire going back to the main plug). Then, twist both of those together as so:
And then plop some solder through, making sure it does indeed go all the way through.
Then to shrink on my heatshrinkable boots (glue inside). The cheap ones from Jaycar took a fair while to shrink. I think next time it will be Rachem brand for me, same as I use at work.
Then finish off the rest on "A" bank:
Its starting to look like a harness!
A bank complete:
Now that I had practice it was onto "B" bank. Running the wires, fitting off the plugs and before I knew it I was getting near the end. One thing I did notice is there was no consistency with which way around the KB wire sits in the plug (left or right). So I am assuming we are only energizing a coil so it does not matter which way around they go in:
Well, that being said I finished off all my plugs and it is starting to look the part:
Tomorrow I just have to "common" up B bank and then splice the wires into the existing plug and she is ready to install!
A bank complete:
The following 3 users liked this post by paulyling:
