Marelli ignition timing tune possible?
Old 08-24-2016 | 11:09 AM
Paul_59's Avatar
Banned
Originally Posted by jamesholland
Its a PROM in the stock processor, EPROM in the windowed processor. It uses a bootstrap programme to write and verify the PROM, there is no read capability hence the need for a bit of skulduggery which will require some custom circuitry and software. There is no need for any Marelli decoding utility its a standard Motorola 68705 processor so any compatible disassembler will be adequate.
I found this document on-line which appears to be the same PCB:
http://www.dinoplex.org/PDF/Marelli%...%20Diagram.pdf there is a lot in there for an ignition only controller but I expect 50% of it is support for fail safe operation.
I'm familiar with MS I looked at it a few years ago but dismissed it, to make it DIY they have made a lot of compromises.
James please be aware that the Marelli MED120B as described in the site you linked to and fitted to Ferrari Testarossa is not identical to Marelli MED123E fitted to V12 Jaguar so information on the former is of limited use to those wishing to reverse engineer 'our Marelli'
Good luck all the same
  #42
Old 08-28-2016 | 02:57 PM
jamesholland's Avatar
Yes I noticed that, comparing the two PCBs the primary difference looks to be in the position sensor interface which is a VR sensor for the Ferrari but is a logic signal in the Jaguar setup. the main architecture looks to be the same. ECUs from the same manufacturer and era tend to be variants of each other rather than being unique.
The Marelli system is a little different from many ECUs of that era because the processor has an internal ADC and external timers rather than the more conventional set up of an external ADC and internal timers. I'm currently looking to source a spare ECU to do the experiments on.
FerrariGuy (05-22-2020)
  #43
Old 08-28-2016 | 03:30 PM
Sarc's Avatar
As a Marelli XJS owner, and an XJ40 owner who fitted the Andy Stoddart timing bracket and was very pleased with the performance, I'm watching this thread closely to see what you guys can come up with.
  #44
Old 08-28-2016 | 04:16 PM
xjsv12's Avatar
DAC6614 5.3 Litre Ignition control module catalyst USA
DAC7889 5.3 Except USA
DAC6613 5.3 Except catalyst
DBC12473 6.0 Litre From VIN (188105)
DAC11511 6.0 From VIN (196706) 91 RON fuel
DBC12473 6.0 Ignition control module
I have DAC5870 in my car
  #45
Old 08-28-2016 | 08:52 PM
warrjon's Avatar
Hopefully that should just be signal conditioning for the VR sensor.
  #46
Old 08-30-2016 | 10:42 AM
What I've been able to source is a DAC7485, its on its way from the US.
xjsv12 (08-31-2016)
  #47
Old 08-31-2016 | 10:08 AM
Jonathan-W's Avatar
I woke up this morning remembering a little tidbit from 1978.... setting cam timing on my 1275 build (10k cam) chain dives only set one link or another... you can get NEAR your timing setting but to get the cam right on.... there is (dah dah duh)
The OFFSET Woodruff key!
would a offset Woodruff key do the same thing as JapThugs' MOD?
(Looking into it...) the cam timing and the front damper use different Woodruff keys
and can be set independent of each other....
sadly, do not think there is enough overlap to get 5 degrees...
The following 2 users liked this post by Jonathan-W:
warrjon (09-01-2016), xjsv12 (08-31-2016)
  #48
Old 09-01-2016 | 05:40 AM
warrjon's Avatar
The problem is the advance curve, messing with base timing on the Marelli will effect the whole curve, not sure how good this would be........
  #49
Old 09-01-2016 | 03:54 PM
Japthug's Avatar
If you ever experienced Andy's timing advancing bracket for AJ16, which advances the timing 5 degree, you know how wonderful it is and it causes no negative effect.
Hence I tried this mod. 5 degree is not a problem at all. Moreover, it does change the engine character. No negativity.
As someone said before, it will be better to fabricate the crank sensor bracket than to slot the timing disc. It can be done without disassembling the fan unit, belt pulleys, harmonic balancer etc... In addition you can easily change the setting. 10 degree will be dangerous. 5-6 will be the safe point.
The following 2 users liked this post by Japthug:
Jonathan-W (10-27-2016), xjsv12 (09-02-2016)
  #50
Old 10-18-2017 | 03:20 PM
I did get a spare ignition ECU but I've been working away for most of the last year. I plan on looking at this again soon but I need a connector to power up the ECU. What connector type is it? I'm still away so I can't check.
ronbros (10-18-2017)
  #51
Old 10-19-2017 | 03:03 PM
I put in an offer on a complete loom that was accepted so I will have all the connectors now. I'm still looking for a cheapish injection ECU to play with as well.
  #52
Old 10-20-2017 | 03:52 AM
Daim's Avatar
There is no way of doing this without massive reworking on the timing cover plate. The screw holes are cast into the cover and the sensor sits between them. You'd have to grind off one of the mounting points, weld on something etc. - a lot of work for maybe a few gains which won't really do anything because the Marelli V12 is basically the perfect ignition setup.
  #53
Old 10-21-2017 | 07:44 AM
Japthug's Avatar
So I fabricate the timing plate. slot the hole and cheat the sensor + ecu. It did change the engine characteristic. There is always a margin when engineering the engine, and with 100 ron and very clean gas in japan you wont have any problem by advancing 5 dgree. it revs sharper and you can feel the power gain.
The following 3 users liked this post by Japthug:
Daim (10-22-2017), Greg in France (10-22-2017), ronbros (10-22-2017)
  #54
Old 10-21-2017 | 01:09 PM
Daim's Avatar
Ikuma! I always wondered what your user name here was!
(damien)
Japthug (10-22-2017)
  #55
Old 10-22-2017 | 03:04 AM
Some Day, Some Day's Avatar
Oh, so JapThug is the guy who runs this site!
ƒWƒƒƒKーX300/XJS ƒƒ“ƒe情••ƒpーƒc”フ”„ HP‚ヨ‚‚、‚ア‚サ!
I've found it very helpful. Especially for replacing my stereo. Some of the stuff shown there is pretty impressive, and beautifully documented.
いつもお世話になっております!
(Okay, that was a website when I added the URL - still is, but looked really weird. Major 文字化け....)
  #56
Old 10-22-2017 | 06:16 AM
Japthug's Avatar
(damien)
Hi Damien!
Funny isnt it?
18 years ago when I was wearing a hip hop clothes... My friend called me Japanese thug LOL
Daim (10-22-2017)
  #57
Old 10-22-2017 | 06:18 AM
Japthug's Avatar
ジャガーX300/XJS メンテ情報&パーツ販売 HPへようこそ!
いつもお世話になっております!
こちらこそお世話になっております。
Didnt know you have such a beautiful website... Could you let me add it to the link of my page?
  #58
Old 10-22-2017 | 06:24 AM
Of course - I'd be honoured. (^_^)
Always very glad to meet another XJS owner in Japan.
JarodL
03-07-2024 01:39 AM
Sprayall
05-30-2021 08:13 AM
PMKimpton
08-03-2019 08:22 PM
XJsc-guy
11-23-2015 01:56 PM
Sprayall
09-03-2015 07:49 PM
Quick Reply: Marelli ignition timing tune possible?
