Matching thermoplastic paint
The base coat is awfully thin. My clear coat started blowing out about 2 years ago now. On the hood and roof it is flaking, but the entire deck lid, which blew out months ahead of everything else, is just consistently flat now.
I don't think there is any chance you could get down to the base and apply a new clear coat, but I am assuming since you mentioned a color match that your intention is a new base and clear, right?
Should be easy enough to go to a local PPG or something with your color code and get a pint or so mixed up to see what you think. Try painting somewhere inconspicuous, like on the inside of the deck lid, to check whether it matches. Btw the Jag code for regent grey is LDL
Hi Mark- I have an 83 with thermoplastic gray paint (either Seville or something f else I can’t remember) which was heavily crazed. When stripping it off I was surprised to find one fender was base and clear... obviously repaired accident damage. The match was pretty good! So it can be done, but... I bet with new clear it would look funny. So maybe go for a single stage paint like PPG DCC: https://buyat.ppg.com/RefinishProduc...9-1D6AAC087000
I love DCC because I’m a terrible painter! Lay it on thick, pick out the bugs and dirt, and sand it till it shines! That won’t work with metallic though.
I went for a full repaint on mine instead of trying to match because it was all crazed. Wow going bare metal with thermoplastic paint was an insane process. The paint melts before it sands off. If you’re going bare metal let me know because I have some specific products/methods you’d need to use.
-John
-John
I’ll be repainting my car soon. I’ll be matching the original BRG on the car.
Would love to hear anything you might recommend.Thanks.
-John
-John
I had zero luck with aircraft brand stripper. I think I tried a couple of other consumer type brands and this paint didn’t behave like normal car paint would. It’s almost like trying to strip powder coat. Stripper is cheap enough for you try it on your own though. Maybe a body shop supplier has something better.
To get the paint off I used 3M Green Corps Roloc 36 grit discs (which are little... 2” maybe) on an air powered angle grinder to scuff away maybe 80% of the color. I did my best to avoid touching the metal with the angle grinder, so the primer was showing through but not metal. Then I used 3M “Purple” 80 grit on a 8 or 10” dewalt buffer to take the rest off down to the metal. On a normal car you could sand down a hood in ten minutes with a buffer and 80 grit...
Hi Warrjon- is your XJ-S an 89? Thermoplastic was over by 86 or 87. If you car was an 89 then it was normal paint which behaves as you photographed. The thermoplastic just didn’t budge with stripper for me. It is worth it no doubt for Mark SF to try stripper, but I expect he’ll have the same problem I did. -John
One of the Jaguar production managers, a Mr Deryck Waeland, I think it was, once described the problems with it in the JEC magazine. Spot repairs failed very quickly and they couldn't wait to get rid of it. Jaguar were definitely sold a pup with that paint system.
There are numerous kinds of paint stripper available in hardware stores, at least out here. The traditional stuff is based on methylene chloride. Awful stuff, but effective. Then there are various safer modern versions, like 3M Safest Stripper (soy-based solvent I think).
I suspect that the methylene chloride stuff is the one that works on TPA.
