Measuring Fuel Pressure on 1992 XJS
Hi forum, i want to keep an eye on the fuel pressure on my xjs, since its a facelift xjs with all fuel connectors to be some kind of unique style with olive seals it quite hard to just slap gauge in.
What im thinking - to cut the return fuel line in half and put 3/8 T-Fitting with clamps and 1/8 27 NPT for gauge
or also i thought, can i cut it and put AN6 T-fitting with 1/8 NPT, but question is what size feed and return lines are, can i put AN6 fitting on the ends?
if there any easier way, please let me know, all this fuel hoses are N/A and i dont want to screw things up.
Maybe you can get a used rail on Ebay and modify that one then swap over. Remember to get rid of all fumes before using a torch on the rail !
On my ‘92, After replacing the plain rubber portion of the fuel lines, I cut it and put in an inline gauge with a couple of fuel injector clamps. Nothing fancy. Can’t remember if I put it on the supply or the return. I guess you could put it in one of the crossover hoses. It registers about 30 pounds where I put it.
iconic
06-01-2016 11:44 AM
JigJag
05-18-2016 08:22 PM
