Metallic sound on startup
I've been experiencing a strange noise on startup and I'm hoping someone can offer some help pinpointing this. It sounds like a scraping metal sound, after I turn the key and it spins over. I'm thinking it is the starter. It doesn't do it every time, but somewhat regularly. Usually after I've driven it a while and not on first startup. The car always starts up just fine, no hesitation or delay ever. It happens with AC on or off. There's no real misbehavior of any kind, other than this noise. Whenever I try and record the sound, it doesn't do it. Go figure. Car has 46k miles on it. Anyone got any insight, and is this something to be concerned with? All help is much appreciated!
Ryan
Ryan
bigcatrescue (10-28-2021),
Greg in France (09-16-2020)
Thanks for the tip Grant. So I read through the X300 section on timing chain tensioner rattles, and I don't believe that's what I've got. It's not a rattle I hear, and it runs smoothly and quietly at idle. It's more of a scraping sound, just right after it turns over and only for a second. My inclination is it's the starter or flywheel I hear. It sounds "dry" or like a metal scraping. And it is infrequent but recurring. Should I just replace the starter? Seems cheap and easy to be sure.
So now you've got me paranoid about the chain tensioners. Am I going to have to replace those sooner or later? Thanks.
Greg in France (09-17-2020)
I agree with Jeff.
Dont throw money at it, the AJ16 is TOUGH.
The only tentioner needing attention, at some stage, and some never, is the top one. That is a distinct RATTLE, enough to really scare you when it strikes. NO damage occurs, just that noise at first fire, cold or hot.
Heat shields, YES. My X300 had a stupid rattle, and a rubber mallet, and tap, tap, tap, all around found the big one on the exhaust manifold the culprit, a quick reshape (bend the sucker) away from the manifold, still silent today.
OK
Starters do go home, but rare.
Flex plates crack, usually a knocking sound.
OK
Xjeffs (09-17-2020)
Thanks to all for the help. It's not a heat shield rattle or high pitched tinny buzz. I'm familiar with those. My hunch is the starter/flywheel and I spoke with my mechanic this morning and he agrees that it could be a broken or missing tooth or the solenoid/pinion is not completely disengaging/sticking. I'm translating here so forgive me. I've ordered a reman Bosch starter from RockAuto and hope to get it on in next week or two. I'll get back to the board with updates.
Grant Francis (09-18-2020)
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Got my new reman Bosch starter installed today. Mechanic is confident it was the pinion gear sticking. I’ll need to give it some more time to see that the noise is gone for good and will report back soon. Starter cost was $160 with $30 core charge and $125 install cost.
Grant Francis (09-24-2020)
I heard the dang scraping noise again today after getting starter replaced yesterday. It happens so infrequently yet recurring that it is really puzzling. I cranked 6 times trying to record it but it didn’t do it. Car runs fine and no unusual sounds when idling etc, just after startup. Air is not on. Ideas anyone? I will keep trying to record it.
30+ for each.
I am still hearing top chain tentioner chatter. Mine was like that, and got worse until I replaced the top tentioner.
Have a read of my Doco I wrote at the time, those tentioners are an issue, even the update units.
Its all to do with the cam lobe profile "back feed" to the top chain. The AJ6 had no issues, as their profile "up" ramp was softer than the AJ16.
To my ears I don't hear a chatter coming from the timing chain. It's more external and a metallic buzz sound. The engine idles and runs perfectly quiet and smooth and there is no chatter or other noise coming from timing chain or internally. The sound is not there at any RPM. It is only after initial turn over. In these sound clips it almost sounds like a heat shield but not so much in person. Kind of sounds like a scraping.
Grant Francis (09-26-2020)
30+ for each.
Greg in France (10-29-2021)
Dell Gailey
08-23-2018 03:07 PM
