Mincer Mounted on my XJS
After looking around for a Camera Mount, I decided to try and make one to my own Specification.
So I 'Borrowed' the GF's Mincer and mounted it on the Bonnet/Hood of the Car.
See Photo:
No need to drill any holes, as the base has a 1000mm (4in) rubber sucker, which works by 'flipping' a lever, to extract the Air.
After which I removed all the 'Mincer Parts' which were only held in place by a Single 'Clamping Screw'
See Photo:
Then I cut the Top of a 'Mono Pod' (single pole Tripod)
and screwed it into the Tripod Mount on the Base of the Camera and Clamped the Camera and 'Mono Pod' Stub, back into the Mincer with the same Clamping Screw.
See Photo:
The Suction of the 'Mincer Mount' is so strong, that it would easily hold my DSLR, although I am going to test it out in various positions, with my compact Camera.
See Photo:
See Photo:
See Photo:
The following 2 users liked this post by plums:
Grant Francis (04-13-2016),
orangeblossom (04-13-2016)
I knew someone who had a beer keg mounted in a Vauxhall Viva.
It could also be driven down the street on the starter which was
hooked up to a discarded diesel bus battery.
And it had the rear seat bar system ripped from a RR.
All done by a very, very bored UK expat working as a diesel
mechanic on night shift.
I wouldn't even begin to try this not knowing what that thing can stand. Just seeing that it holds stationary and hoping it will work at 60mph isn't enough. Just get a gopro. You are going to lose that camera and probably put a dent somewhere in the car anyway, then you will still have to buy the gopro, but also replace the camera and fix whatever you broke.
Trust me, it isn't fun. I've had a spinner come off at 35mph and got lucky it hit my a-pillar and not something with paint on it.
No I wasn't Lol
I wanted to record some Trips, in Hi Definition and as such was wanting to do this by using a DSLR Camera that would give me the kind of result that I was looking for.
And this works every bit as well as I had been hoping.
The following 2 users liked this post by orangeblossom:
Mac Allan (04-13-2016)
The following 2 users liked this post by ptjs1:
The Leaper must be mounted on the Mincer to hold it more proudly aloft.
Sort of like The Flying Lady On Steroids.
Mind you don't let the tail droop in the mincer ... cats don't like that much.
The following 3 users liked this post by plums:
