Mirror switch
I've done it, but it's a PITA. The backside of each switch is held together by press fit brass pins. You have to lever them out with something like a brad remover tool. Once the back is off, the switch can be disassembled. There is a very fragile ring of copper inside that forms part of the contacts, and it is frequently corroded to pieces. If so, game over for that switch. If it's OK, clean it and the other contacts inside and reassemble. Some dielectric grease will help prevent corrosion.The operation of the switch is non-obvious, and is about the dumbest design I've ever seen. Then they put it in an area where it can get water intrusion, and pray it works. Typical Lucas junk. If there is a substitute that would come close to replacing it, I'd love to find it.
The following 2 users liked this post by jal1234:
EvertXJS (03-22-2022),
Greg in France (03-22-2022)
