Missing relay?
Received 10,872 Likes
Probably not. To simplify production Jaguar often installed wiring and sockets for a variety of equipment levels even if the car in question wasn't intended to be equipped with xxx-item. Often this is market-related with (for example) German market cars having some gadgets and gizmos not used on USA cars or UK or whatever
Grant Francis (02-26-2020)
Mine is a 1990 Convertible,,, and there I find an AC relay,,, and another (I forget what the "other" is). If you can switch on your AC with a multi meter hooked into 85 or 86 ports (I think this would be the "switch" lead) and see if you get juice... Electrics isn't my strong suit (by any stretch) but power here would switch on the higher amp power to the AC electro magnet to engage the AC clutch...
Original item Bosch. 0332014113
Replacement https://www.ebay.com/itm/Relais-0320...53.m1438.l2649
Cheers AOI
Jaesteban (02-28-2020)
