modern 5 litre XJR engine into XJS
probably a bit of a repetitive theme..
has anyone heard of any transplant of a 500 bhp modern Jag V8 into an XJS?
I did a quick google search ,but nought showed up.
I presume the V8 would fit the engine bay, but perhaps the quadcam 8 is wider than the old 60' V12. I don't know.
The wiring would be a challenge too..
Sometimes I think the point is not to be "cheaper" but to have more power and be "Jaguar" but then again I've been wrong before.
For under $10K you can buy a brand new 500hp Chev and have it installed and running
I can relate to the challenge aspect and pride of keeping it Jaguar.
I'd bet that the wiring harness would be the worst part. The control models are easy to find and disconnect but the wiring for necessary and unnecessary systems is all mixed together.
You could either get the entire harness out of a donor car, pick it apart and remake it. Or you could get the pinnputs and invent your own custom harness that fits your car.
Either way, it will be a lot of time and work and something to be proud of when you turn the key a the cat roars to life.
Received 1,236 Likes
yes its doable, anything is doable when it comes to engine/trans swaps!
the jag V8s are ford engines, at least it stamped or cast in many components, with ford part #s.
and in todays wiring systems there are available all types of wire harnesses, just look up car wire harness.
i have used a universal wire kit,put into a VW turbo car for a customer,worked out fine!
for security use a standalone,like viper kits,etc. do all kinds of stuff ,one i like was remote start, from across the parking lot!
people would get close and i'd start it up ,engine took a kool rev,and idled down, nice exhaust sound.
anyway just do it! a good learning education,and fun along with it.
I thought about that -does the compression ratio need to be dropped the same as in a supercharged engine?
I don't know if there is room under an XJS bonnet for two hairdryers, though.
Could get a bit busier than usual under there..
Twin turbos under an XJS bonnet- car is in Sydney
WTB[NorthEast]: 17, 18 wheels from xjr, xkr etc
88xjs_Tony
08-28-2015 11:17 AM
Andrew McVey
16
08-27-2015 07:21 PM
