Is my thermostat broken?
Yes, Sir!
I did as Master Grant instructed. (Even before seeing clarifying posts from Doug and Grant. Because by now I learned to trust to do what they say!)
Drilled the hole through the 'S', installed t-stats with the hole up at 12 o'clock, put new gaskets, closed everything up, filled with new coolant. (Man, this cat is thirsty! I kept adding and adding and adding the coolant. And still keep topping off.)
Put the new oil filter and what seems like 11 quarts of oil.
The kitty is back on the road! Took a lap around the neighborhood. Next week will attempt a longer drive, and will keep watching the thermometer...
Grant Francis (07-30-2017)
