My turn, rough running, idle
Some good news....David Boger is sending me a TPS and ECU, so at least I can swap out and eliminate those two from the list AND if they check good I'll have a spare set (which you all know I'll need sooner or later!) If none of you have delt with David at "everydayXJ" your missing a gold mine of great parts at a great price. I've been doing business with him for some time and he is TOP NOTCH!!!!!
Ok, its getting weirder. I decided to duplicate yesterday, luckily its basically the same temp and PA outside. First off I went to jaguarfuelinjectionservices website and got his CTS chart, temp vs ohms. I pulled my plug and read out the sensor and it seemed to jive with the chart. Started the car right up and went on the same trip circuit as yesterday, no problem, car ran/idled fine (like yesterdays trip#1).
2nd trip 1 hour later car started fine yet idle was slightly, slightly mind you lopey and there was some pinging/clatter on acceleration like I'd expect on a super hot day with low octane fuel (car still ran OK but this is falling into place with yesterdays runs)
3rd trip.... and here's where it gets interesting, one hour after 2nd trip (remember I'm doing exactly what i did yesterday, also remember 3rd trip went south right out of the gate yesterday) temp gauge still just below "N" at the start...car started and ran AMAZING!! No lopey idle (not even a little like trip 2) no "pinging" upon acceleration, none, nada, ZIP. Car ran like a scalded dog on the same trip circuit as 1, 2 and yesterday by 3 it was in the dumps.....I dunno, I surrender!
I had my paper clip in hand to push it in the CTS plug when it failed to behave on start-up for trip 3 yet the car behaved amazingly and way better then just an hour before plus its actually warmer out. Go figure?.....stumped and dumbfounded!
Ok...trip 4 one hour after trip 3....still no problems, only slight pinging under hard acceleration.
My '91 XJS 5.3L coupe (auto) just quit in a parking lot one day. After replacing the Crankshaft Position Sensor, It rens MUCH better, and the poor idling problems have gone away, as well. It acted like bad sparkplugs or injectors, missing and stumbling at idle. Now it idles very smoothly.
#30
MC36
US Lower Atlantic
09-01-2015 07:34 PM
