My turn, rough running, idle
Old 03-31-2015, 12:46 PM
JTsmks's Avatar
Car has original "Lucas" fuel pump and 75K on the Odo, anyone know the longevity of the original Lucas pump?
Old 03-31-2015, 04:48 PM
JTsmks's Avatar
Pulled condensor thingy, no joy. Checked coaxial, no joy. Cleaned power resistor connectors, no joy. Siphoned 2 gals of fuel out of tank ( agitated first) no debris/water. I'm curious to see how it runs in the AM
Old 04-01-2015, 09:21 AM
RagJag's Avatar
JTsmks, I would try to help but I have a 4.0 with which, finally after two years chasing a bad idle is fine now. Keep at it, it will happen.
RagJag
JTsmks (04-01-2015)
Old 04-01-2015, 10:23 AM
JTsmks's Avatar
Some good news....David Boger is sending me a TPS and ECU, so at least I can swap out and eliminate those two from the list AND if they check good I'll have a spare set (which you all know I'll need sooner or later!) If none of you have delt with David at "everydayXJ" your missing a gold mine of great parts at a great price. I've been doing business with him for some time and he is TOP NOTCH!!!!!
Old 04-01-2015, 10:46 AM
JTsmks's Avatar
Ok, its getting weirder. I decided to duplicate yesterday, luckily its basically the same temp and PA outside. First off I went to jaguarfuelinjectionservices website and got his CTS chart, temp vs ohms. I pulled my plug and read out the sensor and it seemed to jive with the chart. Started the car right up and went on the same trip circuit as yesterday, no problem, car ran/idled fine (like yesterdays trip#1).
2nd trip 1 hour later car started fine yet idle was slightly, slightly mind you lopey and there was some pinging/clatter on acceleration like I'd expect on a super hot day with low octane fuel (car still ran OK but this is falling into place with yesterdays runs)
3rd trip.... and here's where it gets interesting, one hour after 2nd trip (remember I'm doing exactly what i did yesterday, also remember 3rd trip went south right out of the gate yesterday) temp gauge still just below "N" at the start...car started and ran AMAZING!! No lopey idle (not even a little like trip 2) no "pinging" upon acceleration, none, nada, ZIP. Car ran like a scalded dog on the same trip circuit as 1, 2 and yesterday by 3 it was in the dumps.....I dunno, I surrender!
I had my paper clip in hand to push it in the CTS plug when it failed to behave on start-up for trip 3 yet the car behaved amazingly and way better then just an hour before plus its actually warmer out. Go figure?.....stumped and dumbfounded!
Ok...trip 4 one hour after trip 3....still no problems, only slight pinging under hard acceleration.
Old 04-03-2015, 11:27 AM
JTsmks's Avatar
Update, day three, still running fine. Leaning towards CTS but not the CTS but the plug/wires as that was "messed" with 3 times the day she corrected herself.
Old 04-03-2015, 08:55 PM
Received 10,517 Likes on 6,947 Posts
God find.
I reckon the CTS is fine also.
The wires about 6"?? from the CTS join up with the ATS wires in that black sleeve stuff, and a dry solder splice in there "could" be the gremlin.
Broken wires inside the CTS plug are common, and I think somewhere you have covered that?.
  #28
Old 04-11-2015, 08:30 PM
JTsmks's Avatar
Hopefully "bumping" for another members benefit isn't frowned upon.
Old 04-13-2015, 07:30 PM
mkinn's Avatar
Default Tried a CPS?
My '91 XJS 5.3L coupe (auto) just quit in a parking lot one day. After replacing the Crankshaft Position Sensor, It rens MUCH better, and the poor idling problems have gone away, as well. It acted like bad sparkplugs or injectors, missing and stumbling at idle. Now it idles very smoothly.
  #30
Old 04-13-2015, 09:20 PM
JTsmks's Avatar
There's no CPS's on the Lucas ignition 5.3's. Good tip for those with Marelli ignitions though.
JarodL
03-07-2024 01:39 AM
Raul Lara
09-14-2015 07:31 PM
Jjscruggs1
09-03-2015 07:46 PM
laserguy
09-03-2015 02:02 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
Quick Reply: My turn, rough running, idle
