My x300 needed a playmate...
... So I bought an XJS! Say hello to Jasmine!
As my son is using Ruby the X300 as a daily, my wife said we needed to get something fun while we were young enough to enjoy it (we're grand parents now). This particular XJS has been taunting me all summer. I thought it sold, but it came back up right after the "young enough" comment, so I reached out to the seller, and it's now the second Jaguar in the fleet. Its a 1996 4.0 wearing her original paint, top and interior. It's a nice 20 footer and the flaws are just enough that I won't mind driving her.
Issues to address first are the alternator and a high idle that I hope to tackle this weekend. Could use some new trunk struts and I'm sure will will be due for some other maintenance before I plan a spring outing. I'm sure I'll make a list that reaches the floor before the week is out.
The following 8 users liked this post by SparkyGage:
92/93 XJS (11-16-2021),
Doug (11-16-2021),
Greg in France (11-16-2021),
Mkii250 (11-17-2021),
OldCoastie (11-16-2021),
and 3 others liked this post.
SparkyGage,
Great purchase! I really like that late Turquoise colour on the XJS!
I'm sure you have your own views as to whether you love them or hate them, but I'd remove the somewhat ungainly add-on rubbing strips and definitely remove those rust-promoting chrome arch covers!
Enjoy the car!
Paul
Enjoy the car!
Paul
SparkyGage (11-17-2021)
Great lookin' car! Enjoy, enjoy.
High idle is an easy fix. There's a small allen screw on the top of the fuel pressure regulator in a little well. You have to lean over to see it. It turns clockwise to increase, counter to decrease. Adjust it when motor is warm, trans in "park". I find a small turn and checking the tach until it reaches about 750 works on my 93 4.0. Have the alternator output checked at your local mech/garage. Don't trust the alt gauge...analog reading is always "iffy".
Good luck!
Good luck!
Good luck!
Good luck!
Clean out the throttle body. It's best done by removing it from the intake.
If that doesn't do it, you will need to get it reset by a PDU, WDS, Mongoose, VCM1 (not 2), or some dealer still equipped to reset the TPS. There is a manual way to do it. While you have that throttle body off, enlargen the two holes on the TPS and then tighten the two screws holding it in place just tight enough that you can still move it by hand with some force.
With the throttle body back on the car, you should be able to adjust the position of the throttle body so that its idling at about 700 cold, 580 hot. Once there, tighten those two TPS screws all the way! You'll be doing it by feel.
Greg in France (11-19-2021)
The following 2 users liked this post by Keesh:
Mkii250 (11-18-2021),
That won't exist in an AJ16 engine.
At the moment I'm still looking things over and taking inventory of what's been done (and needs to be re-done).
SparkyGage,
Enjoy the car!
Paul
Enjoy the car!
Paul
AL NZ
07-09-2017 12:08 AM
