Is my XJS the oldest here?
Old 12-18-2011, 02:34 PM
Mish_Mish's Avatar
Now the rear axle...
Attached Thumbnails Is my XJS the oldest here?-dsc01227.jpg   Is my XJS the oldest here?-dsc01270.jpg   Is my XJS the oldest here?-dsc01271.jpg   Is my XJS the oldest here?-dsc01272.jpg   Is my XJS the oldest here?-dsc01273.jpg
  #42
Old 12-22-2011, 08:16 PM
Mish_Mish's Avatar
And the rear end is almost done!
Check out that beautiful undergarment, I am almost done building!
Jaguar XJS Rear Axle - YouTube
  #43
Old 12-22-2011, 08:40 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
Nice work Mish. There is one job that will never need doing again. do you have the camber adjusting hook and tube for front and rear alignment?
  #44
Old 12-24-2011, 03:32 PM
Mish_Mish's Avatar
No, what are those, please tell!
  #45
Old 12-24-2011, 05:10 PM
warrjon's Avatar
They are for setting ride height. The hook is for the rear and tube for the front. The XJS is wheel aligned at a set ride height.
I have attached details for the hook and an extract from the ROM.
Are you going to wheel align yourself or take it to a shop?
I plan on doing mine myself - it is not too difficult all you need are,
4 x concrete pavers a dozen or so vinyl floor tiles and some grease
4 jack stands
2 pieces of conduit about 1m wider than the car
string, a spirit level and camber gauge (you can do it without the gauge using Pythagoras)
File Type: doc
  #46
Old 12-24-2011, 06:03 PM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
HEY, MISH,
dont forget eyeball engineering, and common sense,, can work wonders!!!
  #47
Old 12-25-2011, 08:06 AM
Mish_Mish's Avatar
So very good shop @ $120 is not a good idea?
  #48
Old 12-25-2011, 03:10 PM
warrjon's Avatar
I see no problem so long as they use the tools to set the ride height. Although $120 seems a bit cheap for an XJS if the alignment needs to be adjusted, remember you have had the thing apart and if every component is not in its original location (ie drive shafts matched with rotor and hub) the alignment might be out and is done with shims between the drive shafts and disk rotor. A painfully laborious job.
  #49
Old 12-25-2011, 06:22 PM
Mish_Mish's Avatar
Know all about it, just did all kinds of measuring, when rear axle got assembled. I measured perfectly equal distance between tip of the hub and edge of the frame, it took factory 3 shims on one side and 3 and one slim one of the other.
  #50
Old 12-25-2011, 09:06 PM
Mish_Mish's Avatar
Just found cute "before" pictures
Attached Thumbnails Is my XJS the oldest here?-1.jpg   Is my XJS the oldest here?-2.jpg   Is my XJS the oldest here?-3.jpg   Is my XJS the oldest here?-4.jpg   Is my XJS the oldest here?-5.jpg
  #51
Old 12-26-2011, 10:47 AM
ronbros's Avatar
mish, we seem to think along same lines,
lots of RED kolors, along with blacks.
you gonna be like me,when your done, only drive in fair weather, rain and mud makes a mess of the undercarriage!haha.
Ron
  #52
Old 12-26-2011, 10:51 AM
ronbros's Avatar
and i set mine up with 2* negative camber, so hook tool isnt accurate,for my setup.
also when vehicle is lowered, changes some factory settings.
  #53
Old 12-28-2011, 12:27 AM
Death Kitten's Avatar
looks good. lots of hard work your puttin in there!
Originally Posted by jag_man653
Not to brag, but mine is even older: 12/1975 on the door post. 2W 51180 BW. Take a look at photos and the original window sticker, at my website.
now i gotta go check mine when im back in so cal. Mines listed as a 76 so it could be a late 75 build date.......
  #54
Old 01-08-2012, 03:47 PM
Finally got around to looking at the car.
behold
9/75 Oldest on the forum?
  #55
Old 01-08-2012, 06:33 PM
ronbros's Avatar
this is an interesting thread,
i wonder who has the newest XJS, and show the vin#, with a pic??
  #56
Old 01-09-2012, 08:52 AM
Mish_Mish's Avatar
Why don't we make posting pictures of your "oldest" XJS a requirement here!?
  #57
Old 01-09-2012, 09:00 AM
Mish_Mish's Avatar
Some more pics of my old champ's resurrection.
Attached Thumbnails Is my XJS the oldest here?-88ce9ca312ad203c-large.jpg   Is my XJS the oldest here?-88ce9ca32449e544-large.jpg   Is my XJS the oldest here?-88ce9ca2ec72aae8-large.jpg   Is my XJS the oldest here?-88ce9ca3010212ac-large.jpg   Is my XJS the oldest here?-88ce9ca2a9cd3c54-large.jpg
Is my XJS the oldest here?-88ce9ca29041da70-large.jpg   Is my XJS the oldest here?-88ce9ca2da06ca2c-large.jpg   Is my XJS the oldest here?-88ce9ca2ce7c85a0-large.jpg   Is my XJS the oldest here?-88ce9ca2c100b7e8-large.jpg
  #58
Old 01-09-2012, 09:56 AM
jag_man653's Avatar
behold
Can't see the whole VIN. Can you post it?
Thanks.
  #59
Old 01-09-2012, 08:21 PM
Mish_Mish's Avatar
Starting to rust proof, using spray on truck bed liner, nice stuff...
Attached Thumbnails Is my XJS the oldest here?-20120109_121909.jpg   Is my XJS the oldest here?-20120109_121930.jpg   Is my XJS the oldest here?-20120109_121938.jpg   Is my XJS the oldest here?-20120109_121952.jpg   Is my XJS the oldest here?-20120109_122015.jpg
Is my XJS the oldest here?-20120109_173430.jpg   Is my XJS the oldest here?-20120109_173452.jpg   Is my XJS the oldest here?-20120109_173521.jpg   Is my XJS the oldest here?-20120109_173536.jpg
  #60
Old 01-09-2012, 10:14 PM
87XJSCoupe's Avatar
Quick Reply: Is my XJS the oldest here?
