My XJS V12 Overheating any tips?
Check to see if your Jag has an auxiliary cooling pump. It may be bad and has created an air bubble in the system. This happened on my XJ8. Same symptoms. We replaced the pump, and flushed the system, especially the heater core. Everything in the system needs to flow and circulate. Also, make sure you don't have a cracked thermostat housing. In the later models they are made of plastic and have a reputation for cracking. Lastly, be sure you bleed the system after any work. This is imperative. Best of luck.
Rob
XJ8 VDP 2004
ex: XJ6 1996
Rob
XJ8 VDP 2004
ex: XJ6 1996
Series 3 E Type V 12 overheating had become a chronic problem until we did the following:
- Replaced the factory original radiator core with an aluminum radiator from Wizard Cooling. Radiator shop will do an inspection on the original core.
- Replaced the original fans with new higher volume electric fans (retaining the original shroud)
- Sealed the top of the shroud across the bonnet - blocking shroud bypasses to the original air intake snorkels (raising the air pressure forward of the radiator/ increasing air flow)
- Ducted the port and starboard fresh air intakes directly into the air cleaners (will add some photos)
abonano
25
09-25-2015 10:43 AM
