Need a/c compressor 1994 v12
Jon
Maybe worth researching a bit and please do report back - I also have a '94 V12 and I am sure I will be requiring a compressor at some point.
I don't have this configuration, therefore I am not sure what the answer is, but over the years, I believe many have reported that other compressors will work, but the mounting configuration has to be modified on these other parts.
I am sure if you do a search on these forums, you'll find someone that has been able to modify the mount in some fashion. I don't think there are going to be any easy solutions here though.
See post below, I did not realise the 6 litre mounts were different.
Also on the 5.3 litre, the aircon compressor drive is not part of the water pump belt drive.
Sanden makes all sorts of different mounts, clutches, endplates, and fitting attachments for the 709 style compressors. You have to ensure everything matches.
Greg in France (07-23-2023)
Mike,
That model compressor has to be mounted on the V of the engine and it is integral for the belt arrangement.
If you try to mount a compressor with a different mounting arrangement you won't have any drive for the water pump.
Also, any other mounting arrangement will probably interfere with the bonnet.
Mike,
