Need Head Gasket?
A coolant pressure tester can be employed. It attaches in place of the radiator cap then you pump up the system to 15 to 18lbs of pressure and see where the fluid goes. When not moving and cold a drip can become more visiable.
Might be as simple as a bad radiator cap seal that allows fluid to expel when hot. Small pinholes in a radiator or a leaky side tank is often hard to spot on an xjs.
It'll expand and burp coolant sometimes if the caps are weak or air will evacuate and it'll drop. When changing out my many coolant hoses, 3 of which have burst in the past month, every time I'll do the procedure to the letter and still have to add another couple liters it seems. After a few warm-up/cool-off cycles the coolant amount stays the same. Probably just air leaving thus dropping the level abit.
The level of 1 inch down is normal. Just monitor it and check every week or so and see if the level goes way down. Also, look for leaks on the ground under it, etc...
Harry Peter Rose
02-12-2018 08:04 AM
Napoleon Solo
11-16-2013 04:31 PM
c6hunter
04-19-2009 09:42 PM
