Need headlight help!
I have an 88 XJS with the double round headlights. I've been thinking about changing and have a couple options.
I've found a set do glass euro headlamps with bezels and clips. My question concerning these is if I have everything needed to install. Is there a mounting bracket needed or do these pieces hold them in place.
Second choice is keeping the double round and replace the stock sealed beams with the new aftermarket halo round bulbs. I would get the white halo with bright halogen bulbs. I've replaced all of the other smaller bulbs with led white where ever possible. Tad lights, most parking lights and such so the color would match.
I really want the euro lights but not sure if I'm missing any parts!! And they are pre facelift.
I happen to think the euro headlights suit the car better, but I have the double arrangement now, because RH dipping euro lights are unavailable from the factory and impossible to find in breakers over this side. The double lights are MUCH easier to deal with!
Facelift cars had a much better fixing and adjusting arrangement on the euro lights, involving a plastic frame the lights were mounted in, and if you can find a pair, they can be made to fit with a bit of effort, I am told.
Greg
Received 10,895 Likes
Complaints of poor lighting with the "Euro" lights are fairly common. This is one of those odd cases where some owners actually seek out "USA Spec" parts.....in this case the 4-lamp system, for which you can select from a wide variety of lamps and bulbs.
Not that anyone asked but I prefer the looks of the 4-lamp system. The Euro headlights make the front of the car look like an insect, IMHO :-)
Fletch44
09-28-2015 02:21 PM
