Need Help With '94 XJS AC
Trying to help my friend Hal with AC on his '94 XJS. Key on, AC switch off, system cycles the fan blower and compressor clutch on and off continuously, will not stop until ignition is turned off. However, system functions normally when turned on, both heat and AC. Prior to this, system worked fine. Any ideas/advice much appreciated.
Thanks,
Craig
Thanks,
Craig
Thanks,
Craig
Thanks,
Craig
